Question about Acer Aspire One D250 (99802378332) Netbook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
    Sergeant:
  • 236 Answers
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Posted on Feb 14, 2011
  • leeann Oct 25, 2012
    this is what mine has 1. IDE0 2. IDE1 3. USB FDD 4. USB HDD 5. Network Boot : Atheros Boot Agent 6. USB CDROM
Please help... i have this same problem... i did everything that people post.. I bought the a new harddrive and the the problem still persist... the old harddrive is actually still working when i hook it up to my desktop... i check under bios and there is no harddrive listing under HDD... the bios says NONE. it's the same problem even with new harddrive. So what could be the problem here?
Posted on Aug 22, 2012
3 Suggested Answers
  • 10406 Answers
SOURCE: My computer fell
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Posted on Nov 09, 2009
  • 104 Answers
SOURCE: When I turn on my Acer minilaptop it say: Check
Your BIOS setting or boot order was changed to enable network booting (Intel's PXE).
reboot,tap F2 to enter BIOS and navigate menu to disable network booting.
Posted on Mar 28, 2010
Emachines e525 says no bootable drive
Boot to recovery mode and do a startup repair, if it doesn't help, you can either do clean install or talk to a specialist
Apr 19, 2014 | eMachines 15.6" E525-901g16mi Laptop Lcd...
When I boot my Acer Aspire One, I get a black screen that says: (line 1) check cable connection...! (line 2) pxe-e63: error while initializing the NIC (line 3) pxe-m0f: exiting Intel PXE ROM. (line
Seems your graphic card is fry.But you cant do a test to confirm it.Just plug anohter monitor to the VGA slot and powerup the PC.Test if still no screen that will confirm the problem.
Apr 12, 2013 | Computers & Internet
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire will not start. get message check cable connection! PXE-E63 error while initializing the NIC PXE-M0f Exiting Intel PXE ROM No bootable device - insert boot disk and press any key. Netbook has...
1. It seems that the hard drive is not bieng detected by the computer 2. and from the error message that you are getting it seemed like windows is not loading up 3. I would suggest that you take out the hard drive and put it back in 4. the reason for that is the hard drive that connects from the mainboard is
May 29, 2011 | Computers & Internet
I'm running a Windows 7 netbook- acer aspire one. 32 bit Prossesor- Intel Atom BOOTING ERROR- I press power and the ACER logo pops up (normal) and then: For Atheros PCIE Ethernet Controller...
This message means that the computer cannot see the hard drive. Unofrtunately, this is usually caused by a failed Hard Disk drive. However, you could try removing and re-fitting the hard drive to see if this cures the problem.
Full instructions on removing and replacing the hard drive can be found here:
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Apr 12, 2011 | Acer Aspire One PC Notebook
When i turn on my computer it reads PXE-E63: Error while initializing the NIC and PXE-M0F: Exiting Intel PXE ROM. Missing Operating System
It sounds like it is trying to boot from a network. Enter the bios by hitting the delete key during boot. First see if your hard drive is recognized. If not yours is bad. If it IS listed check the boot sequence and make sure your hard drive is first, or CD first HDD second. Save and try again. Hope this helps.
Apr 06, 2011 | Acer Aspire One PC Notebook
Upon startup before anything else happens (except asking me if I want to press f2 for setup) my aspire one netbook says: For Atheros PCIE Ethernet Controller... v1.0.0.5(1/22/09) check cable...
Press F2 and enter setup as it looks like your device is set to boot from the network instead of your C drive. You can change the boot order in the setup.
Oct 03, 2017 | Acer Aspire One D250 Netbook
When I turn on my Acer minilaptop it say: Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device--insert boot disk and press any key
Mar 20, 2010 | Acer Aspire One PC Notebook
Acer Aspire One D250 (99802378332) Netbook Logo
1,430 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
