Question about HEWLETT-PACKARD Hewlett Packard BLUE HP 14.5" Pavilion dv5-2135dx Entertainment Notebook PC (XH004UAABA)
HP dv5-2135dx won't start after selecting restart
HP 1005 Printer shows scanner error 15 for what no print and scan available
Try stopping and restarting HW and WIA
1. open Start Menu and type in services.msc press Enter
2. 2 tabs at the bottom Extended and Standard, select Standard
3. Now look for the Shell HW Detect
Right click and select Stop
4. Find WIA) (Windows Image Acquisition) Right click and select Stop
5. Now restart both of those services by Right clicking and selecting Start
Mar 07, 2018 | HP Office Equipment & Supplies
SCANNER ERROR 15
Jan 22, 2018 | HP Office Equipment & Supplies
HP TouchSmartIQ772 won't reboot on a restart
windows gone currupt, new installation of windows will solve the issue
Jan 07, 2013 | HP TouchSmart Computers & Internet
Hp 4700 won't print pdf
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows XP platform:
  1. Choose Windows Start button and open the Printers and Faxes window.
  2. Right-click the QuickBooks PDF Converter icon and choose Properties.
  3. Click the Ports tab. Click the Add Port button.
  4. Select Local Port. Click the New Port button.
  5. For the new port name, enter PDF1. Click OK.
  6. Close the Printer Ports window.
  7. Select the PDF1 checkbox, if it is not already.
  8. Click the Advanced tab.
  9. Select Spool print documents option.
  10. Clear the Enable advanced printing features checkbox.
  11. Select the Print directly to printer option.
  12. Click the Apply button. Click OK.
  13. Choose Windows Start and choose Run.
  14. In the Open field, enter %windir%. Click OK.
  15. Right-click the System32 folder and choose Properties.
  16. In the Properties window, click the Security tab.
  17. In the Group or user names list, select Users. In the Permissions for Users list in the Allow column, select Read, if not already selected, and select Write.
  18. Click the Apply button. To save the changes, click OK.
  19. Restart your computer.
  20. Note: For the changes to take effect, you must restart your computer.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows Vista platform:
  1. Make sure that you are logged in as Windows Admin.
  2. Choose Windows Start > Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Properties.
  4. Click the Ports tab. Click the Add Port button.
  5. Select Local Port. Click the New Port button.
  6. For the new port name, enter PDF1. Click OK.
  7. Close the Printer Ports window.
  8. Select the PDF1 port checkbox, if it is not already.
  9. Click the Advanced tab.
  10. Select the Spool print documents option.
  11. Clear the Enable advanced printing features checkbox.
  12. Select the Print directly to printer option.
  13. Click the Apply button. Click OK.
  14. Restart your computer.
    • Note: For the changes to take effect, you must restart your computer.
  15. From QuickBooks, print, email, or create a PDF document.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows 7 platform:
  2. Choose Windows Start > Devices and Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Printer Properties.
Hope that it will work for you,
Thanks,
She Morillo
Dec 04, 2012 | HP LaserJet 4700 Printer
It won't recognize USB ports
Please check this, Go to My Computer and right click. Select manage from the menu. Select device manager on the left hand side and see if there are any ! of any kind that may show missing drivers. If this is the case you may need to go to HP's website and download drivers for your hp mini.
Mar 16, 2012 | HP Mini 1000 Vivienne Tam Edition
I bought an hp deskjet3050all-in-one j610 series today my tower won;t open ids there a way to down load printer to my computer
If you want the drivers or full software for the Deskjet 3050 j610a; see HP's support page: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lang=en&lc=en&product=4066452& . Select your OS (make sure to select the x64 bit version if you have a 64 bit OS). Get and install the full software if you plan to use the buttons on the all-in-one to start scans. (Note: this doesn't include third-party software that may be on the original CD.)
I hope this helps.
(also remember to install the HP software before connecting the USB cord if you are going to use that option. The drivers in the OS often do not support the full feature set (like the scanner) of an all-in-one. If you forgot, disconnect the data cable, uninstall the current driver and restart the computer before installing the HP drivers.)
Feb 05, 2012 | HP Office Equipment & Supplies
I have hP mini 1000 that won't boot up windows. Just shows me Hal.dll error message. How do I fix that if it won't start.
you will need a copy of windows and an external disk drive then have it boot from the cd when it boots select install windows then leave the current drive intact with no changes or if the repair option comes up you can select that. do not select the repair at the first menu unless you are an expert in dos, always go to the install.
Jun 30, 2011 | HP Mini 1000 Netbook
It won't print, says 'communication error' and 'help with printer lights'
1. Disconnect the Printer cable
2. Uninstall the HP Printer Driver
3. Click the Start icon, Computer, go to the Tools menu, select Folders Options, go to the View tab and set Hidden Files and folders as Show hidden files and folders.
4. Navigate to directory c:\windows\system32\spool\drivers\
5. Delete the w32x86 Folder. If cannot be deleted download the printer patch from the hp website
6. Restart the computer with the printer cable disconnected
7. Install the HP printer driver and it will ask the printer cable to be plugged in
8. That is the time that we will be plugging in the printer cable
9. By this time the printer is communicating to the computer by now
Hope this helps
May 29, 2011 | HP Deskjet D2360 InkJet Printer
When I touch the Scan Menu button, and choose scan to computer I get a message that states: No Scan Options I have been scanning for a year. This happened suddenly and I can't figure out why
Hi
Thanks for using FixYa. Due to any reason when the HP Communications process fails the HP Scan application won’t work. To resolve the issue you’ll need to follow the procedure as given below---
  1. Force Quit HP Communications (if running)
  2. Force Quit HP Scan (if running)
  3. Turn the printer off
  4. Turn the printer on
  5. Select Scan Picture from the HP Director application
  6. When the HP Scan application complains, press Reset
  7. HP Scan will then hang, but HP Communications will restart
  8. Force Quit HP Scan (again)
  9. Select Scan Picture from the HP Director application (again)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 28, 2009 | HP Office Equipment & Supplies
HEWLETT-PACKARD Hewlett Packard BLUE HP 14.5" Pavilion dv5-2135dx Entertainment Notebook PC (XH004UAABA) Logo
258 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
