I have a whirlpool duet washing machine and it is stopping half way through the wash. Flashing 02 and F. What is happening? The wash machine is about 18 months old.
  • 5,911 Answers
Click on the following link for an explanation of the "F02" error code.
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases, the drain pump reservoir becomes clogged with debris and does not drain properly. If the pump is damaged and requires replacement, please post back and let me know. I can assist you with locating parts if needed. I hope this helps you.
Posted on Jul 09, 2008
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/02 error code on display?
This error is shown on the display due to:--
Drain time exceeding more then 8 minutes, the water valves will stop functioning and the the water valves turns off and "F/02" will be displayed on the screen.
NOTE: in some cases it has been noticed that 4 minutes the "Suds" error displays, and then 4 minutes later the F02 error displays.
This Will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
Washing machine stop and start flashing o2f
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 02 flashing on washer
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet ht. Model# ghw9250ml1.
replce the board located on the top right side of the chasis
Feb 11, 2010 | Washing Machines
F 02 STARTS FLASHING WHAT CAN I DO TO STOP
i believe that is the code for slow drain condition.pump may need to be cleaned
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet will start washing but then stops and displays 02 then f.
it means your washer isnt pumping out the water...check the drain filter for a clog or an object in it if this doesnt do it call for service there is nothing you can do to fix it
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
