Question about Raypak Pool & Spa
Wen I turn the heat switch, the furnace does not turn on. Wat should I do?
  • 43,501 Answers
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Jan 03, 2011
My electric coleman furnace will not run.
Depress the interlock switch manually as the furnace is starting up. That should give you your answer. Some furnaces (mine) rely on a friction fit of the cover panel to close the switch. Over time, the friction fit stops fitting.
Feb 25, 2017 | Heating & Cooling
When turn on my fire place heater heats for about 5 sec. Then a little white light flash's it turns the in heat colls off blower never turns on
How to Fix a Gas Furnace: Furnace Blower Does Not Turn ...
? 2:51
https://www.youtube.com/watch?v=XjgLbLYsuHw
Jan 18, 2012 - Uploaded by About.com
If the blower in your gas furnace won't turn off, it can cause major problems with your home heating system ...
Electric furnace blower motor doesn't turn on once in a while ...
terrylove.com > Forums > HVAC Heating & Cooling
Mar 7, 2014 - 16 posts - ‎5 authors Hi everyone, I'm having a problem with my Broan Electric furnace lately. Sometimes the blower motor doesn't want to switch on. Sometimes it ...
Oct 24, 2015 | Heating & Cooling
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
When turning on heat after a period of using air
It sounds like the fan limiter switch is going bad. This switch waits until the air temp is high enough for heating the house before allowing the fan/blower to come on. There is another switch that shuts off the blower when the air drops to a certain temp, or it may be the same switch that does both jobs. Hope this helps.
May 09, 2010 | Omega Trane Furnace Draft Inducer Blower...
Carrier Furnace infinity 96.model 58MVP060-F-18114. Furnace heats
Sounds like it could be your fan limit switch. Part costs about 20 bucks and is fairly simple to replace. This limit switch is a safety that prevents your furnace from over heating. Usually when your t/s is satisfied the blower runs for a little longer after the burners have stopped, and the reason for that is the limit switch. The blower is supposed to cool this limit switch to a certain temp. and once it reaches this temp it shuts the blower off. Yours is stuck:(
Feb 13, 2010 | Heating & Cooling
Heat works fine during the day at night it stops if you run hot water power vent turns on then boiler fires is it the presure swith in the power vent its model ck-92fal thanks ron
Turn on the boiler and jump out the pressure by putting a wire between the 2 electric connections only after the unit fires up than put the jumper on, if it runs ok it is the pressure switch.
Jan 08, 2010 | Calvin Klein The Field Controls Company...
Wat do u mean by x clamp m8
To remove MS hardware which is a flimsy Pisces of metal that looks like an"X"
and replace it with screws washers and then and most importantly
screw down the heat sink under the cd drive turn it on let only the
G.P.U over heat ,takes about 10min for a units that hasn't been wrapped with
towels , those units that have been user damaged heat up much faster
reducing the chance of a reliable burn in.
That's it
Knowledge is Power
www.all-xboxrepair.com
Jul 01, 2009 | Microsoft Xbox 360 Console
While switchin on 311oc it blinks thrice n again switch off
ur got software problem so go to ur nearset nokia n tell him to change ur software
Jun 06, 2009 | Nokia 3110 Cellular Phone
Pool & Spa Logo
87 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
