Question about LG Ally Cell Phone
How do I get my lg ally to respond to a voice dialer call command from my Jawbone bluetooth?
  • 437 Answers
Hi bredebar you need to go to settings. Next you need to hit the wirless &network go to the bluetooth settings and make sure that the blue tooth is connect to the phone and audio. If your having a problem with the voice command it is because your ally doesn't have froyo on the ally. You need that to get the voice commands to work. you can go to the open market and put in voice commands for droids. Hope this helps foryo is frozen yogurt great name. There is another new program coming out be on the lookout for it .
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Jan 03, 2011
How to use voice dialer (svoice) with bluetooth on galaxy s5
Corded headsets do not have Bluetooth. Do you have a Bluetooth headset (wireless) handy to test the Bluetooth function properly?
Nov 04, 2014 | Samsung Galaxy S5
I want to make and receive handsfree calls using an LG HBM-730 bluetooth device and an LG CF360 phone. I have the bluetooth and the phone connected and can receive calls and make calls. The kicker is...
Hello.
From LG Documentation:
To make a handsfree call from the bluetooth device (Voice dialing)
- Briefly press the PWR/END button to activate “Voice Command”.
You will get the best results if you first record the voice dialing tag through
your Headset.
Hope this helps
Mar 09, 2010 | Cell Phones
Pairing problem with lg chocolate flip phone
contact jawbone for further assistance because most carriers dont support bluetooth
Jan 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Cannot pair lg voyager with jawbone bluetooth.
Mine wouldn't pair either so I went to the jawbone site and I did this and it worked the first time.
For Jawbone ICON, while the power is off, press and hold down the Talk button and slide the power switch on. When the LED starts to flash red and white alternately, release the Talk button.
1. Press the OK Key.
2. Highlight SETTINGS & TOOLS and press the OK Key.
3. Select Bluetooth Menu.
4. Select Add New Device. (If Bluetooth power is set to off, you will be prompted to turn power on. Select Yes and press the OK key.)
5. Highlight Jawbone and press the OK Key.
Enter the PIN "0000" (be sure to enter four zeroes and not the letter "O") and press the OK Key.
Mar 22, 2009 | LG VOYAGER VX10000 Cellular Phone
Blue tooth voice commands
I had the same problem with a Motorola bluetooth. I had to return it to the store because it was defective. It wasn't a problem with the phone it was the bluetooth.
Jan 13, 2009 | LG VOYAGER VX10000 Cellular Phone
HOW DO I RECORD A contact voice tag lg vu (cu920)
You do not have to record voice tags for your contacts. Go to Tools, click on Voice Command then Settings and finally Train. Follow the prompts and once complete, your phone will them be able to recognize your commands. when you hit the call button on your bluetooth headset, the phone will say "Say a command". at that point you can tell it to call any contact in your list or tell the phone to call a number (i.e. call 601 555 0123). The phone will ask for conformation and then make the call. The phone will also respond to request to check missed calls, check voice mail and tell you the time and date. Hope this helps.
Dec 12, 2008 | LG Vu CU920 Cellular Phone
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
when on your phone vertically press the track ball and your keypads will show up thus allowing you to use you voicemail commands
Oct 28, 2008 | HTC G1
With use of Jawbone, recipients on enV get voice echo
About three months ago I bought the LG En V touch from a verizon store. I planned to use it with my old "New Jawbone" and my new "Jawbone Prime". The phone would nto pair at first then when they finally got it to pair I had a variety of problems. Verizon technicians performe a number of different steps trying to make it work as it was supposed to. They even reinstalled the software after about a week and a half I persuded the Verizon stor manager to replace the phone with a new LG EnVtouch and they exchanged my Jawbone Prime also. The new LG EnVtouch had the exact same set of problems. Neither of these phones worked any better with the bluetooth in my Garmin NUVI either. I loved the design and the features but if it doesn't work why bother. I returned the second LG EnVtouch after aabout five more days of frustration. And went back to my old phone. If you buy one of these and it doesn't work return it fast and let them know what you think!
Apr 20, 2008 | LG enV VX9900 Cellular Phone
LG Ally Cell Phone Logo
202 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
