Question about LG Washing Machines
My washer sometimes will not spin and will have the letters le on the front
  • LG Master
  • 8,220 Answers
Aha the old LE error. I have some notes:
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Problem:
An occasional LE error but always a slow or no spin: Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness. All is Good!!!
Problem:
The seal design on the washer traps water causing mildew to grow.
Solution:
If the door gasket has a small hole at the six o'clock position--it is clogged with soap scum. Use compressed air to blow this hole clear.
This allows water to drain back into the tub
If there's no hole--this is an older model LG which did not have this upgrade
Wiping the door gasket with a rag after the LAST cycle of the day helps prevent debris from accumulating. Some consumers add (1) teaspoon of bleach to a spray bottle with water--and spray the older type gaskets after the final laundry load finished--to keep the gasket clean.
Problem:
The detergent and softner dispenser is gravity feed and builds up with "gunk". It has to be cleaned regularly and while the tray is removable, the inlets are not; so you have to fish out the sludge with a paper towel.
Solution:
This common on almost all front load washers.
Remove the dispenser tray. Remove the blue liquid detergent cup. Add all to the top rack of the dishwasher---run a cycle. This makes much less a chore of cleaning the dispenser tray assy.
Problem:
The washer broke down about 6 months ago (roughly 2-2-1/2 years old). The waste pump went bad. No service reps in the area and the place that sold them to us quit selling LG after numerous complaints. I went to a local appliance parts wharehouse that sells just about every part known to the appliance world and when I mentioned LG, the guy at the counter smiled and shook his head. "You have to order it online.
Solution:
You are correct---parts & service is still lacking in some areas, regrettably.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Problem:
With no error code showing up and the glitchy flickering of the display, I'm eyeballing the main board.
Solution:
Unfortunately--that appears to be the fault (main board) if the lights for the cycles that circle the control panel knob flicker or do not fully "light up".
Main Board Part # 6871EC1121D
Problem:
Getting a CE error code
Solution:
This is a *rare* error.
It's highly unlikely the motor is at fault.
Detergent overuse triggers an "LE" error rather than "CE".
UNPLUG THE WASHER...
First--inspect all wiring connections at the MAIN BOARD (see below instructions). If good...
Inspect the wiring at the motor--remove the rear service access panel.
Remove the 17mm bolt at the center of the rotor--this can be tight as threadlocker is used (I use an 18 volt Dewalt Impact drill).
Pull off the round shaped rotor. Use some care--this rotor has magnets lining the inside of it--it's not super fragile but can crack if hit sharply.
Inspect the two plug connections to the motor for loose or frayed wiring. Also inspect the wiring which runs from the base (bottom) of the washer-to-the-motor. Once or twice--I have found wiring frayed from the gyrating tub assembly (repair as needed).
If no obstruction such as a nail or similar object can be seen in the drum (small holes in tub)...if the drum turns freely by hand--the most likely fault will be the MAIN BOARD has failed.
This job is very simple:
Remove (3) screws at the top of the control panel.
Pull the control panel towards you & upward.
Remove the screws that attach the MAIN BOARD to the Display Board. Install new MAIN BOARD.
Some LG Service Manuals are HERE
Posted on Jan 03, 2011
4 Suggested Answers
  • 3422 Answers
SOURCE: my washer is not working
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Goodluck..
Posted on May 27, 2008
MNTECH
  • 1543 Answers
SOURCE: my lg front load washer
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Posted on Feb 08, 2009
SOURCE: I have letters le flashing on my lg front loading
The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
Posted on Nov 10, 2010
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
Hope this helps.
Jun 29, 2011 | LG Washing Machines
Washer gives the LE error when trying to spin. What is the LE error and how can I fix it?
Unplug machine, hold down the Start/Pause button 5 seconds while still unplugged. Plug back in and then do a rinse/spin to see if LE code come back.
Nov 19, 2010 | LG WM1814CW Front Load Washer
I keep getting a code le why?
Has a large load size been used with a gentle wash setting
Has the washer been overloaded?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
My washing machine keeps shutting off and has the letters LE in the display. What's going on?
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
It could also mean the hall sensor is defective and will need to be replaced.
Feb 12, 2010 | Washing Machines
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
579 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
