The laundry washer blinking sud how can I fix it?
  • Washing Mach... Master
  • 8,220 Answers
Aha the old SUD problem. This error occurs when too much soap OR the wrong soap is used in the HE washer. I have a manual and some notes along with a video by the Handy Hippy HERE
Posted on Jan 03, 2011
SUD AND F-35 PROBLEM
SUD= The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future
As far as F35. Check your owners manual to see if its in there. Also if you remove the top lid ( a couple screws in back hold it in place) and check inside you will get the technician diag sheet which will have codes.
Jul 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I have a frontload he washer. My question is, will using a regular laundry detergent instead of he laundry detergent cause problems with the washer.
top load detergent will suds a lot and detergents made for from load washers wont suds very much at all, suds ina front loader will cause it to not spin or drain very well while i know it is more expensive you should always use detergents with the HE logo on the package
Jul 25, 2011 | Washing Machines
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
Washing machine flashing de
I haven't seen a DE is it maybe DC? these are the known codes
DL - Door unlocked when washer is running DS - Door is open when washer is running NF - Washer tried to fill but was not successful due to clogged water lines or closed water valves. ND - Washer is not draining it can also mean that the unit senses a small clog or frozen hose. DC - Unbalanced load prevented the washer from spinning. When the weight of the laundry is about 1kg the center of the weight gets shifted. redistribute the load and restart or add more clothing.
SUDS - Too many suds are detected, the unit will be put on hold until the suds are reduced the it will go back on. when it completes the wash it will flash END and SUDS. make sure you use HE (high efficiency) detergent
Oct 10, 2010 | Samsung Washing Machines
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore washer with suds saver. I do not
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
See the Sears Parts site and / or their Answer Site for manuals.
Answer:
http://www.managemyhome.com/
Parts description and possibly manuals:
http://www.searspartsdirect.com/partsdirect/index.action
Nov 08, 2009 | Kenmore Washing Machines
"clean" light is blinking
Check the following:
1. Is the overfill protection float able to move up and down
freely? Press down to release.
2. Be sure the water supply is turned on to the dishwasher.
3. Check for suds in the dishwasher. If foam or suds are
detected by the dishwasher sensing system, the
dishwasher may not operate properly or may not fill with
water.
Suds can come from:
1. Using the incorrect type of detergent, such as
laundry detergent, hand soap, or dish detergent for
hand washing dishes.
2. Forgetting to replace the rinse aid dispenser cap
after filling (or refilling) the rinse aid, or spilling rinse aid into the tub (rinse aid causes suds to occur).
3. Using an excessive amount of dishwasher detergent.
Mar 16, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Whirlpool Duet Front Load Washer WFW8300SW00 Problem: I am using HE detergent and using less than the recommended amount; however, there is always a small ***** of suds sitting on the seal when I open the...
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
Jul 21, 2008 | Whirlpool Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
