Simpson Clothes Washer - Esprit 450 Bowl fills with water. Agatating cycle does not work. Timer proceeds to next cycle and water empties and then continues to spin dry.
    President:
  • 1,654 Answers
This machine has a hystory of motor control board issues and this sounds excactly like the symptons. The timer part of the controler seems to be skipping. The problem is the whole control board may need replaced.
Posted on Jan 03, 2011
  • Dcramer531
    Dcramer531 Jan 03, 2011
    Other things that can make the washer act like this are.
    Test the lid switch
    Inspect under the washer for soot (clutch)
    Inspect the agitator
    Test the water level switch
    The lid switch will keep the washer from agitating, this is a safety device, The pressure switch tells the washer it has enough water in it to start washing, if this is clogged or kinked it will not start the agitation. Since it is spinning I wouldn't worry about the motor coupling or the pump since it is pumping out the water as well. The agitator should have some small plastic dogs in it that make it agitate, these can be worn or broken but if that were the case that machine would run but not agitate.m I would check the lid switch first, then the pressure switch. On most models there is a small lastic hose coming from the tub to the control board and it hooks to a round sensor. Take the hose off and blow through it to make sure it is free and clear.
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
My washing machine spins but doesnt complete the spin cycle
does it drain all the water out/ If not then check your pump filter.
Oct 04, 2014 | Simpson Esprit 750 Top Load 7.5kg
Simpson washing machine will not fill
faulty control board or timer
Nov 19, 2017 | Washing Machines
Water level
Probable causes:
Faulty water inlet valve - unplug washer, if water continues to fill
replace the valve.
Water level switch, hose or dome faulty - service the assembly.
Timer faulty - unplug washer, if water stops filling test timer.
Regards,
Dennis
Aug 22, 2014 | Simpson Esprit 750 Top Load 7.5kg
My simpson esprit 450 washes dirt/sand into the tub - how can I clean the
Hi just read your posting.The only way you can assess the tank is to remove the inner bowl.This is quite difficult.I can help you with removing the inner bowl but I think the easiest way is to fill the machine on a High water level and when it stops filling and starts to agitate pause the machine and advance the cycle to spin and let the pump drain out the sandy water.Give this a try the reply back on how you got on.
Jul 14, 2012 | Washing Machines
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Jul 06, 2009 | Washing Machines
Washing Machines Logo
176 people viewed this question
Top Washing Machines Experts
