Question about Samsung RS2534 Side by Side Refrigerator
Samsung refrigerator motor is running but I don't think that fan is cooling the motor
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 03, 2011
I have replaced the cooling fan motor twice in my Samsung Refig. Model RF267 and the fan does not run. I have previously replaced it 2 other times and it fixed the problem.
Usually a defective fan is caused by a defective control board that does not send the correct voltage to the fan in turn burning out a new fan motor. You will need to replace both board and fan motor. APPLIANCE 911
Dec 11, 2015 | Samsung Refrigerators
We have a Samsung FR323TEDBSR french door refrigerator that is becoming very noisy
It sound like the fan motor is going bad. They will spin fine when spun by hand but will start to rattle or squeal when running. if it is the model I think you have the entire panel is replaced as a complete unit. This is not hard to replace. It looks like you have already had the panel out. It just has a couple wire to unclip. and clip the new one in.
May 15, 2014 | Samsung Refrigerators
Samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like someone will need to examine the fan motor and test the voltage to the fans inside and outside the refrigerator. You will need to have this done to eliminate what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
9_16_2012_3_30_31_pm.jpgDA31-00103A
Sep 14, 2012 | Samsung RS2630WW Side by Side Refrigerator
Freezer side of my RS2534WW Samsung is not working, fridge side is fine, evap coil fan is running,,, what could be wrong , it's only 7 years old
Your indications does not make sense! Your unit has ONE compressor that uses ONE evaporator coil to cool both sides. So if the FREEZER side is not cooling the fridge side should not cool either! Are you sure you don't have the freezer and refrigerator sides reversed?
Aug 14, 2011 | Samsung RS2534 Side by Side Refrigerator
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Freezer fan quit working after ice took over (kids kept leaving freezer door open) we defrosted and the temp will not drop below 40 degrees is there a reset to restart the fan?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No,
Probably wrecked the fan motor...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Samsung RB195ABBP (187 cu ft) Bottom...
Refrigerator side not cooling freezer sides is working i had the fan motor replaced but still fridge side not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
dygjdgh
Jul 14, 2010 | Samsung RS2534 Side by Side Refrigerator
FAN DON´T WORK IN THE RIGHT SIDE (REFRIGERATOR)SAMSUNG RS21DDSW
I had this problem, Motor is gone. The drep motor is a pile of ****. Go to ebay or buy a replacement direct from korea, The 12v doesnt appear on the cct as the fan doesnt operate unless the door is shut. Hope this helps anyone who google this
Mar 26, 2009 | Samsung RS2630AWW Side by Side...
Fridge not keeping cool RS267LASH
Hi Adshegern,
I think you have a fan problem. Your refrigerator mus have a bad fan or not working fan. I suggest you full out the refrigerator and open back lower cover. Two months ago, I have a problem like your. I fixed by replace a fan. You have to options to fix it.
Option 1. Check your refrigerator's fan with voltage. It think it should be 120VAC. If yes, you can buy a fan from electronics store (it cost about $12.00 to $17.00). they you remove the old fan and its motor out. Install the new fan in. Then you need to drill 4 holes to tie the fan. By doing this, you keep the fan running stable. The fan won't vibrate.
Option 2. You can go online to this website partstore.com and buy an exactly the one you need and replace the old one. It cost about $40.00.
Good luck
Mar 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
88 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
