Question about Raypak Converter, N To P Mv 105a - B/Pak
The furnance will not come on - Raypak Converter, N To P Mv 105a - B/Pak
  • 43,501 Answers
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Jan 03, 2011
My furnance keeps turning off and I could go to furnance flip switch on and it only last 5 minutes then shuts off again
You may want to check the limit switch or you could have a issue with the gas valve or transformer. I would check the low voltage transformer first, Sometimes I have found that under load the transformer will open ( quit working) and will close after power is removed and it cools down, It indicates a bad internal connection.
Jan 26, 2013 | American Standard Trane Ge Gas Furnace...
To what terminals do the two wires coming from the a/c unit connect to on the furnance?i have r w g y c on the furnance board. its a carrier tech 2000 a/c and a rheem criterion 2 furnance
The 2 wires that come from the outside unit will connect to the Y(Cooling) and the C(Common) terminals on the board. It doesn't matter which wire goes to either one, they both work either way. Have a good one!
Sep 01, 2010 | Heating & Cooling
RUUD Air Conditioner not turning on
Need to check the breaker to the unit at the electrical breaker box. You should have a dual 60 amp breaker that runs the unit. Also if you removed the front of the furnance on the inside the system will not work unless the front of the furnance is on. There is a safety switch that will not allow the system to run with the door off. There could be the problem if the breaker is on and electricity is supplied to the unit that switch may be out and need replacing. The furnance is operated on 110 volts the condensor (outside section) operates on 240v you need to insure that the proper voltage is supplied to both.
Since both units work together yet operate seperately if the furnance comes on and the condensor doesn't then there is an electrical problem at the condensor (more than likely the contactor switch) if the condensor comes on and not the furnance then there to is an electrical problem (either 110 volts not supplied) or the switch to the safety cut off is bad. Now if neither furnance nor condensor comes on there could be improper power to both or a bad thermostat since the thermostat activates both furnance and condensor. Good Luck on repairs
Dave
Sep 04, 2009 | Ruud UBHC Air Conditioner
Manual on how to clean Coleman furnace model # DFAA084BBTA
Here's a web link to the Technical Manual for your furnance. This should contain all the tech specs for your unit.
http://www.winfieldsupply.com/images/HVAC/dfahtechguide.pdf
Also, please give Coleman customer service a call at 1-877-726-5362 to obtain a Owner's Manual for your particular unit, which should contain the periodic service schedule for your furnance. Here's a link to the Coleman site with maintenance tips for your furnance.
http://www.colemanac.com/homeowners/maintenance_tips.asp?prodLine=1&ProdID=0
Hope you found this info helpful and best regards!
Aug 06, 2009 | Coleman Heating & Cooling
Furnance not starting
Try cleaning the flame sensor. Its the most common problem on todays furances. You should clean it with a fine grit sandpaper or emery cloth once a year.
Apr 11, 2009 | Heating & Cooling
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
Fan in furnance
any furnace with a blower will go on your electric bill but it really should'nt draw enough power to raise your bill noticably unless it's running constantly.
Jan 24, 2009 | Coleman Propane Forced Air Heater...
Carrier furnance keeps running
check for open limit switch, their are multiple, check return air filter.
Dec 17, 2008 | Heating & Cooling
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Raypak Converter, N To P Mv 105a - B/Pak Logo
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
