Question about Car Audio & Video
I need a schematic for my Delphi PN 12244929 GM 10357894 Cd Player Stereo. The back lights are out which are blue LED's. Not sure if is the voltage supplied to the LED's or they are burnt out. I have the problem on 2 different stereo's, possibly it's the supply to the stereo from the instrument lights. Rick
  • 93 Answers
SOURCE: CD player ejects CD
ok,replace the belt in spindle motor,that is only problem
Posted on Oct 26, 2007
Deesul69
  • 14 Answers
SOURCE: OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Posted on Nov 28, 2007
SOURCE: Kenwood RXD 501
Do you already check the thermal fuse on the primary side of the transformer
Posted on Oct 01, 2008
  • 44 Answers
SOURCE: Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
Posted on Jun 28, 2009
  • 1126 Answers
SOURCE: Hi , I have a Sony car Stereo CD player Model #CDX-L350
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C385125
Frank, try this link for wiring connections...looks like there are 2 different pin outs available here. Hope this helps.
Posted on Aug 23, 2009
Testimonial: "Thanks Very much , it was just what I was looking for , Thanks Again Chouch 3"
I need the wiring schematics for a 1995 oldsmobile cutlass cierra
wiring schematics for what? audio?
if so
1995-96 Oldsmobile Cutlass Ciera Stereo Wiring
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 3 1/2" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
GM uses the same colors for all audio wires
I know a picture would have been better, but I think this could help
Aug 08, 2011 | 1995 Oldsmobile Cutlass Ciera
Wire harness to switch from stock stereo to cd player will not fit the wires that are supposed to? so what wires are the speaker wires
Not sure I understand your question. Did you buy a harness adapter for GMC, or are you trying to just cut the connector off the factory radio and solder it to your CD player? If the latter, below is the color code for your factory wiring.
1994 GMC Sierra C1500 Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Nov 20, 2010 | 1994 GMC Sierra
I need a wiring diagram for Delphi Delco 15091316
I'm looking for a factory stereo wiring diagram for Delphl Delco part#12240691 GM Part #22723439 The plug is 24 holes but think it's a 16 wires.
Oct 25, 2010 | Delphi Car Audio & Video
I have a 2001 dodge ram, when I connect either the ground wire, power wire, or both from the cd player I am installing, all of the dash gauges quit working.
make sure your not connecting the power wire to the power for the gauges here is the wiring diagram
2001 Dodge Ram 2500 Truck Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Aug 16, 2010 | Car Audio & Video
Need wiring schematic telling me what wires in the harness go where.
red-power wire to power when ignition is on.yellow-battery back-up to powersource that stays live when car shut off.black-ground wire.blue-remote turn on for amplifier.blue/white-power antenna.orange or orange/white-dimmer to make deck lights fade when headlights get turned on.white and grey are your front speakers and green and purple are the rear,not sure about speaker sides though
Jan 10, 2010 | JVC AM FM CD DET FACE CAR STEREO
Memory wire for 1997 cadillac deville need to know how to wire it to my cd player
Yellow wire on cd player is for memory and needs to be on constant voltage that doesn't shut off when car is turned off.
Here is the wiring diagram for the car:
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Nov 12, 2009 | 1997 Cadillac DeVille
Replacement headphone for Delphi car DVD
ebay?
most all infrared headphones are interchangeable just do a search and should find plenty of sources to buy from you dont need to get gm ones.I know audiovox works as i have used these on gm vehicles before
Sep 11, 2008 | Delphi MV10021 Car DVD Player
Light
You need the remote to turn that light off.
Jun 09, 2008 | Sharper Image Slim One-CD Stereo with...
Car Audio & Video Logo
417 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
