Blue color stripe? - Computers & Internet
  • 2,418 Answers
You can try cleaning the lens but most of the time there is a bit of damage to the chip that transfers the light to image. It will not go away. Sorry.
Posted on Jan 03, 2011
Cat 5 cable
The normal color code is. Orange white, orange, green white, blue, blue white, green, gray white, gray. the wire using for network only 2 pair. That is 1,2,3,6. For normal telephone - use blue pair (4,5). For pabx system use. 3,4,5,6. Connection. You can use any Color code If both ends are same.
Jul 02, 2012 | Computers & Internet
I need to know which connectors go to which O2 Sensors on my 2005 Jeep Grand Cherokee 4.7L 4WD. Can you help?
Hi, the easiest way to tell is by the signal wire color. These are the signal wire colors:
right front: dark blue/pink stripe
left front: dark blue/light blue stripe
right rear: Brown
left rear: dark blue/yellow stripe
Apr 17, 2011 | Jeep Grand Cherokee Cars & Trucks
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
