I have a vizio e550vl and i have a hdmi problem.the hdmi will work when only i have one source hooked up.if i have two or three sources hook up at the same time whichever one is hooked up to hdmi 1 bleeds over to the other two ports causing it to show whatever is on port 1.
Fujitsu
  • 29 Answers
SOURCE: Hitachi P50H4011
You need configurate the DVD nad the salellite receiver output to turn on the HDMI out.
Posted on Dec 28, 2007
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
chesterpendi
  • 195 Answers
SOURCE: Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
bugoy31
  • 1238 Answers
SOURCE: no hdmi signal on a panasonic viera tv, they used to work
sounds like you need to update firmware
Posted on Jul 23, 2012
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
Vizio tv says no signal on any of the hdmi ports
Unfortunately, you fried the HDMI controller. Not necessarily part of the power supply "main board." (Not sure which board is the HDMI controller in your specific TV. It's usually a separate board by itself). Easiest workaround is to use the "Component" cable connectors. The downside is you only get 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people only see 1080P when viewing Blu-Ray discs. Aside from replacing the HDMI controller, the cheapest workaround for multiple source connections is to buy an HDMI to Component Converter A/V box, which allows you to connect multiple devices to one box with one set of Component cables connecting to the TV. Then select various "sources" via the box.
Mar 05, 2016 | Vizio E370VL 37 in. LCD HDTV
Vizio 42" E421VO 1080p Widescreen LCD only shows 480p why
In order to help you out with this, I would need to know which input you are attempting to use, what the source content is and what kind of cable(s) you have hooked up to the target input.
Apr 28, 2014 | Vizio 42" E421VO 1080p Widescreen LCD HDTV...
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Getting hdmi problems between vizio e550vl and uverse
more likely the receiver or a connection than the set
Aug 27, 2012 | Vizio E550VL 55 in. LCD HDTV
I have a vizio 55 in. e550vl the hdmi ports quit working when lightning hit a tree by the house i think maybe a surge came through the satellite if i was to replace the main board would that fix it i...
I am having the same issue with our Vizio E550VL TV. Does your TV show No Signal on the screen? I was able to get regular AV to work with the Yellow, Red, and White cable to work but none of the HDMI ports would not work. If it does not power on at all it may be the power supply. I had to order the main board to get it to work correctly. Vizparts.com is where you can order it from.
Aug 10, 2011 | Vizio E550VL 55 in. LCD HDTV
How do you get the crispiest picture on the M420nv TV?
Put the TV in the oven! Nyuck nyuck nyuck. Sorry... seriously though, if you use HDMI to hook up your input source to the set you shouldn't have any problem.
May 17, 2011 | Vizio Televison & Video
My HDMI port seems not to be getting the conncection just had the cable here and they had to hook it up through componet to suggest anything besides taking it to a repair shop or buying a new tv?
did you program source to transmit signal through the HDMI
a lot of sources need to be set to send signal through HDMI and also sending audio on lots of sources need to be specifically set also
good luck!!
Apr 15, 2011 | Vizio L32 32 in. LCD HDTV
Can you hook the vizio sound bar to an av receiver for use with all devices hooked to the receiver thru HDMI?
Why not ? It doesn't know what the source at the other end of that RCA or digital cable is.
Picking the VSB200 as an example.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Vizio-VSB200-Speakers-manual/id/23494ag923/t/2/
The manual shows connections to just about anything.
Not knowing anything about YOUR receiver, you MIGHT be able to draw digital audio out somewhere. Analog audio would be available at any Tape Output. Your receiver
Mar 23, 2011 | Vizio High Definition Sound Bar
No audio on vizio from source
there should not be a special setting that you need. When hooking the analog audio to the HDMI 2 input, it should read automatically. Note: The HDMI Input is for HD Video and will only support 640x480 at 60Hz from a PC. Use the RGB
PC input for a greater selection of PC formats.
Mar 23, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
