Question about Bosch 1 - 1/8" Reciprocating Saw RS5
When using the saw, it sometimes won't move the blade, I just hear the saw moving inside, but the blade won't move. The blade also "jams" or gets stuck easily now. Wondering if I have worn out the clutch? Feels like its slipping...
  • jaforocks Jan 03, 2011
    Thanks for the info Mike!
    Cheers,
    Wayne
  • 520 Answers
Yes that is probably what has happened or may be some gear damage in the drive assembly.
Posted on Jan 03, 2011
Testimonial: "Mike gave me a very quick answer and was very thorough!"
    Is it fairly easy to replace the clutch? Getting it fixed professionally would probably be more expensive than buying a new one.
  • mike42353 Jan 03, 2011
    anymore it just doesnt pay to have them repaired. but, sometimes you can find parts on ebay at a good price or even the complete saw pretty cheap. i have bought some for parts that had bad motors but everything else was fine. also there are a lot of places on line that sell the parts. its not that bad to do. i take pictures along the way to help me remember how things got together.
I have a Dewalt DW321 corded jig saw. I can't get the blade to release. The blade blade holder seem frozen.
place the shaft in the fully up position and give the collet holder a tap to move it back up further
sometimes they jam from metal, dust and grit
sometimes a bit of WD-40 or like item will lubricate the movement and make it easy to pull up
Nov 18, 2017 | Dewalt Saws
How can I fix a jammed Ryobi miter saw blade?
Probably go a piece of wood between black and safety cover. Unplug from power before checking
Apr 30, 2014 | Ryobi 18 Volts Cordless Miter Saw 18v P551
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Cordless 18 volt lithium ion sawzall hums and clicks blade wont move
I don't know what model you have but Milwaukee sawzalls use a wobble shaft and wobble plate to turn the rotary motion of the armature into the reciprocating action of the blade. If you motor is working (hums?) but the blade won't move one or more of these parts are broken and hitting eacher (clicks?) inside the gear case. You or a repair center will have to take the gear case apart to find our what's broken and determine whether it's worth repairing.
Jan 27, 2012 | Milwaukee Tool Saws
I can't unlock the blade.
Do you mean the chain won't move, or you can't get the blade off? The chain brake must be off to allow the chain to move. The chain brake handle has a housing that engages a gear attached to the chain brake inside the cover where the blade is attached. The brake must be off to remove the cover (usually held on by two nuts). The blade tension screw should be loosened to allow the blade to be removed, then retightened when replacing the blade. Tightening it pushes the blade out from the saw, so if it is tight, you won't be able to remove the blade. Hope this helps.
Aug 27, 2011 | Garden
My powermatic table saw is very hard to raise and lower the blade and i have removed the knob that tightens the handle so the blade does not move and its still very difficult to move the blade
You need to do some maintenance on your saw. First unplug it. Then blow out the sawdust from inside the saw, especially around the trunnion ways and gears and worm gears that engage them to raise/lower and tilt the saw. Use a good quality lubricant to lube these worm gears and the shafts and pivot points. I use motor oil, have for years, and find it does a better job and lasts longer than any kind of grease or silicone. Use an oil can with a long spout so you can direct the oil where needed, then move the saw up/down or right/left to work the oil into the worm gear and mechanism. In a pinch WD40 is fine, though it won't last as long. Periodic re oiling will maintain the mechanism in peak condition, and the drops of oil you spill in the process won't do any damage to your so. No, it won't get gummed up with sawdust. Try it, you'll like it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 08, 2011 | Powermatic Saws
Garbage Disposal Ace 2000 model 47982.... The water won't drain out of it and the sink is backed up and hasn't gone down for a whole day now. It seems like the blades are turning. I've been...
Hi David,
Are the blades actually turning or is just the motor running?
First, turn off the power to the disposal at the circuit breaker. Do not put your hand in until you do this.
If you hear the motor running, but not the blades, then the blades are jammed. On most disposers you can put an allen wrench in an opening under the unit and move the blades. If the blades move freely, then your drain line is probably plugged.
If the motor runs, but the blades don't and they will move freely by hand, then the disposal needs repair.
If the blades are jammed with food, you can clear the jam with your hand and the allen wrench trick from underneath.
Once the disposer is freed up, run cold water down the drain for a few minutes to harden any grease build up inside. Then running the disposer should get rid of the hardened grease.
By the way, most disposers have a reset button on the bottom of the motor should your disposer jam and turn off or trip your breaker.
Orange peels, etc. will not harm your disposer. A good way to keep it clear is to put egg shells down it periodically. The shell action will scrape junk off the inside of the disposer.
You can also keep the disposer clean of grease buildup by pouring some baking soda in the disposer followed by a mix of hot water and vinegar.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My blade gaurd will not automatically rotate out of the way when lowering the blade to make a cut , Ridgid 12' compound miter saw
MS12502 has a solid arm actuation to move the blade guard, this is either bent, broken, unattached or otherwise not functional. sometimes the moving parts get full of sawdust and a major cleaning is all thats needed. generally all woodworking tools should be blown out with air after each use or end of day.
actual model number of your saw would be more helpful.
Dec 02, 2009 | Ridgid Reconditioned 12 In. Compound Miter...
Sears 10 inch Radial Saw wont run
Try blowing out the motor with compressed air, while rotating the blade by hand. (unplug it first.) Then press really hard on the reset, as sometimes they won't move much at all but will have popped. Use a center punch gently if you have to to push on it. If that doesn't yield results, I'd try spinning the blade by hand a bit and then pulling the start switch to turn the motor on. I once got one to crank up again by doing this, and it continued to work afterwards. (Be careful!) Seems like they are like old starters sometimes that get dead spots in the windings....
I know those are pretty basic ideas, but I have one I've managed to keep running for years as well, and would hate the thought of having to replace it... Also seems to me once I had to remove the cover from the motor and repair a shorted wire inside that was touching metal somehow. And that was only apparent after a similar jam of some sort, as I recall...
Best of luck and encouragement, anyway!
Jul 23, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
MK101 won't start
Can you move the blade with your hand or does the blade not move at all or is the sound buzzing even with the blade spinning cuz mostly this sounds like the blade is stuck and should be able to free it by moving it by hand unplugged all the debris from the tile dust can lock up the blades sometimes if it is not cleaned properly
Jun 20, 2009 | Mk Diamond Wet Saw with Stand
Bosch 1 - 1/8" Reciprocating Saw RS5 Logo
402 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
