Question about Dell Inspiron M5030 Laptop
My laptops brightness is too bright even on the dimmest settings. But usually when i restart my laptop it fixes itself. I think it only fixes when i am on battery power.
  • Anonymous Jan 03, 2011
    No i have tried fiddling around with the power options settings but thats not the problem. Even on the lowest brightness settings for my screen the white colors are very prominent. I usually have to restart my laptop to fix this but it always comes back. sometimes it will stop letting me change the brightness with the F4 and F5 keys are well as my volume with the F8 and F9 keys.
    I just got this laptop and i noticed there are a lot more power options in Win 7 than vista but all i really want right now is to stop it from automatically making itself brighter regardless of current F4 and 5 brightness settings.
    Master:
  • 362 Answers
Go into battery power option bottom of your desktop and its available to be set on user prefs there i hope its that simple for u :)
Posted on Jan 03, 2011
  • kent mac Jan 03, 2011
    did it lead up to this or was this something your suffering from since new? and is it led or lcd because an led screen is super brighter in comparison
    I am unsure but I just restarted on the power cord and the difference is greatly noticeably. When I restart on power the screen is fine and it doesn't have any problems. When i unplug the power cord it gets super bright and grays become white.
On my laptop screan it gon a bit dak and i ned help 2 fix this
Hi , I think your laptop brightness settings had been changed. So try this to increase and reduce the brightness , contrast. Select start-> control panel -> appearance & personalization -> display . There you will have options like Adjust brightness , Adjust resolution etc., on the left side of your window. You may adjust in this way.
May 20, 2014 | Samsung HCM422W 42" Rear Projection...
I have a brand new Lenovo IdeaPad P400 touch screen laptop, and it's been working perfectly expect now I can't adjust my brightness settings at all, it stays on its lowest setting even when I have it...
You have been to Settings and tried to ajust the brightness there? Restart it and then go to settings and set the brightness there, All the best Kolbrun
Nov 04, 2013 | Lenovo Computers & Internet
Boots up but black screen
If your laptop screen is not working and is blank, you are out of luck as far as working on your computer. However, while there may be a major problem you need to troubleshoot, there are some easy solutions to keep in mind as well, such as brightness settings and your power source.
1.Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2.Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3.Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4.Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5.Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
Sep 05, 2011 | Sony VAIO VGN-TXN15P/B Notebook
Dell optiplex not booting from xp cd
1. Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2. Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3. Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4. Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5. Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
I hope you find it very helpful. Best regards from fixya
Aug 15, 2011 | Dell OptiPlex SX270 PC Desktop
My acer aspire laptop has crashed---the power light is still on but the screen is black and it doesn't respond to anything I do! I can't even turn it off properly---is there a reset button or...
Aug 15, 2011 | Acer Computers & Internet
Blank screen
Aug 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
HP Pavilion dv7-1129wm blank screen upon booting of machine
Jun 16, 2011 | HP Pavilion dv7-1129wm Notebook
How can i fix my laptop black screen? I can hear it coming on, but no image on the screen.
Instructions Things You'll Need:
  • AC adapter
  1. 1 Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
  2. 2 Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
  3. 3 Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
  4. 4 Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
Oct 04, 2010 | Computers & Internet
LAPTOP DISPLAY,
ok for some reason by running the game morrowind it fixed my display. Dont ask why, I dont know but thanks anyway. Maybe it has something to do with the mods that I have put on it.(morrowind)
Dec 14, 2008 | Fosa CY25 Laptop
Dell Inspiron M5030 Laptop Logo
337 people viewed this question
Alun Cox
