Question about Canon PowerShot S2 IS Digital Camera
My lens won't go in and when I try to take a picture it clicks and the code E18 comes up.
    Guru:
  • 1,894 Answers
Lens error comes when your lens is not able to retract insde.
This can be due to some kind of dirt or any sand particles stuck inside the lens. this may also occur when the camera is dropped from a height which damages the lens system.
Please give a small tap to the camera lens. It works in many cases. If not you will have to consult a authorized service center
Posted on Jan 15, 2011
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 10, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
Jan 08, 2009 | Cameras
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 15, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital... E18 Problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 17, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
Canon pwershot s1 IS E18 error code
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 14, 2008 | Canon PowerShot S1 IS Digital Camera
E 18 problem
i had this problem with my camera the same make it happened twice and E18 appeared both times its a fault with the lens its has been knocked out of place and thats why it will not close mine was because it was dropped on the floor with the lens out! i blagged to the company that i brought it from that it just happened and they swapped it for a new one both time in the shop. its worth a try
Dec 01, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Problem with E18
The "E18" error code indicates an error that involves the lens unit or lens cover. Or it may appear if you apply pressure to the area surrounding the lens while handling the camera. Remove and reinsert the batteries to see if the error code will reset. Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it
Oct 02, 2006 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
