Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox workcenter c2424 displays RAM ERROR - Xerox WorkCentre C2424DN All-In-One Laser Printer
  • Xerox Master
  • 4,338 Answers
Control Panel Help Button
Your system's control panel provides you with information and troubleshooting help. When an error or warning condition occurs, the control panel displays a message informing you of the
problem. In many cases, the control panel also displays an animated graphic showing the
location of the problem, such as the location of a paper jam.
To view information about how to fix the problem, press the control panel's Help button,
which is labeled with a "?" symbol. You can press the Help button at any time to get additional
information about the message or menu displayed on the control panel.
PhaserSMART Technical Support
PhaserSMART Technical Support is an automated, Internet-based support system. Use your default web browser to send diagnostic information from your printer to our web site for analysis. PhaserSMART Technical Support examines the information, diagnoses the problem,
and proposes a solution. If the problem is not resolved with the solution, PhaserSMART
Technical Support assists you in opening a Service Request with Xerox Customer Support.
To access PhaserSMART Technical Support:
1. Open your browser and go to www.phaserSMART.com.
2. Enter your system's IP address in the browser window.
3. Follow the instructions on the screen.
Posted on Jan 03, 2011
  • JDTec
    JDTec Jan 03, 2011
    Also::::
    1. From the System Setup menu, go to Information --> Troubleshooting -->
    Service Tools menu.
    2. With the cursor at the top of the Service Tools menu, press both the Up Arrow
    and Down Arrow buttons to display the Hidden Service menu.
    3. Reset NVRAM is in there
    If that doesnt work try below.
    1. Turn the system power ON.
    2. Wait for the Xerox logo to begin moving across the display.
    3. Before the logo is centered on the display (stops moving), press and hold the Back and Info buttons on the control panel.
    4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. You should find it in the function sub menu.
13387.48:16806 error code on Xerox Workcenter C2424
From the Xerox Solution center --
Solutions for : Fault Codes 13,XXX.4X: Thermal Error Related Fault Codes: 13,xxx.4x Solutions ranked by relevance:
  1. Make Sure the Room Temperature is Within Operating Temperature Specifications
  2. Make Sure the Power Source is Not Causing the Behavior
A previous firm I worked at had these units. Do not plug them into a surge protector of backup power supply system.
Mar 22, 2011 | Office Equipment & Supplies
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Linux or Mac OS X support for Scanning
You need to download the correct drivers for the OS.
You can go to this link:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=C2424&Xlang=en_US&Xcntry=USA&source=XOG
And download drivers from there according to your OS. Please Select proper OS otherwise you will be downloading Windows by default. On this link there is also utility programs free and so forth; you might find something useful.
Please Rate :) Porfavor
Oct 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Mar 28, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
183 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
