Question about JVC HR-S3500 S-VHS VCR
Tape won't load
My nine-year-old HR-S3500U VCR refuses to allow the tape basket to load. An acquaintance suggests replacing the mode switch, which he described as a circular electromechanical device that's probably mounted on the main board. Is he right?
The childlock feature might be active try holding the power button on the remote till the vcr turns on. when the VCR turns on try putting a tape in and see what happens I happen to own this very model and has been in service since july 98 and has over 10k hours on it and still works like the day i bought it
I had that same issue a few years ago
Posted on Nov 04, 2008
After a long period of non-use,of my VCR, I recently tried to play a new VHS tape. It loaded properly, but refused to play it.
Could be the belts have become too old for the unit to function. you could try to take the unit apart to clean them.
Mar 25, 2015 | JVC Hr-a591u 4 Head S-vhs Hi-fi Stereo Vcr...
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
My HV-MX1U is definitely over 14 years old and was one of the best electronic devices I ever bought. Nothing was ever replaced or fixed in it so, obviously whatever parts like belts or etc need to be...
Probably both. There is a mode or position switch that tells the processor what position the deck is in. If that has failed that could be a cause also 14 years for belts is a very long time. You may find a kit on fleabay but switch wise, I doubt it.
Mar 24, 2017 | Aiwa HV-MX1 VHS VCR
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
Load completion switch is not making, usually for mechanical reasons, but could be bad switch...accordianman
Mar 03, 2008 | Computers & Internet
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
Machine won't stay on
Hi I'm not familiar with your model, but what it sounds like is a bad "end sensor" on your machine. There are photo sensors on either side of the cassette basket which is what holds the tape in the machine. There is a light source that ends up inside the cassette when loaded, which shines both left and right. There is a section of clear tape inside the cassette at both the beginning and end of the tape. When the sensor on the left side sees light through the clear tape, the VCR knows you have reached the end and goes into rewind, when it sees light on the left side, it knows you have reached the beginning of the tape, and stops rewinding. This sensor is also used in some models to sense when you insert a tape in the basket. In that case, if the right side end sensor goes bad, the VCR always thinks you are trying to load a tape, so it doesn't want to give them up, and when you rewind, it never senses the beginning of the tape, so it will shut down when it reaches the beginning, and could even snap the tape. I'm 99% positive that is what is wrong with your VCR, it is an easy fix, but unfortunately, you won't likely find a repair shop that will sell you the proper sensor. I hope this helps in some way. Good Luck!
Jan 13, 2007 | JVC HR-A592U S-VHS VCR
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
176 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
