Question about LG L226WTQ-BF Monitor
Hello, my lg flat screen monitor appears to work at start of computer powerup, since I can the "dell..." etc. but then after 3 seconds fades to black. When I click on the buttons on the side of the monitor, I do get the options in full color but don't know how to navigate through them or if I need to regarding this issue. Do you have any suggestions? Thank you! Janeen
  • 583 Answers
Since the monitor is working, it sounds like the computer is not booting up. See if you can get it to boot up by pressing F8 during the DELL screen (before it fades to black) (you may have to press F8 repeatedbly)... this should take you to a screen for Windows startup options. Choose Safe Mode and see if you computer starts up completely. If it will start up into safe mode, then there is a driver or something that is preventing windows from starting normally. Have you added any software or hardware recently before this happened? If so, while in safe mode remove any software that you've recently added and see if you can start Windows normally after that. If not, right click on the My Computer icon (either on the desktop or in the Start menu) and choose Manage from the pop-up menu. Click on Event Viewer. Depending on whether you are using Windows XP or Vista or 7, the following will differ slightly.
Under Event viewer, look into the System and Application logs for errors to see what is causing the computer to stop loading. Let me know what you find so I can help you troubleshoot further.
Posted on Jan 03, 2011
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
My DELL monitor is not working I got a second
More likely to have problem in the inverter circuits, check for short between Emitter and Collector pin of the four transistors as shown in the pictures.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
A lock symbol appears
Hello. On this Dell flat panel the menu access appears to be locked, if the lock symbol you are referring to is from the monitor itself.
You should be able to lock or unlock the OSD by pushing and holding the Menu button for 15 seconds.
Oct 23, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
When I start my computer my Dell S199WFP Flat Panel Monitor does not go on and stay on. It comes on for about two seconds or and switches off. I have to turn it on about 20-30 before it will stay on. While...
Hello
You have capacitors on the monitors power supply that have changed value. Soon they will keep the monitor from turning on at all. Send it to a company like mine or take it to a local repair person.
Aug 02, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1703FP monitor issue
reduce the hardware acceleration on it. I resolved it by reducing acceleration and changing my screen size. It works. I wanted higher resolution but it doesn't seem to be possible for some reason.
Good luck.
Mar 01, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
New 19" flat screen monitor only shows analog on the screen
finwiz,
When you on your computer, does any thing appear on the screen, some text display/logo etc.?
If yes then:
  • After making power on your computer start pressing F8 till boot option menu appears.
  • Then select safe mode and if it works, then goto device manager and re-install driver for your display.
If no then:
  • Check out the connection from monitor to computer and try. If still no luck then post comment whats you did and what was the result.
Thanks
Iqbal
May 12, 2008 | Gateway FPD2275W LCD Monitor
Screeen comes on --then goes blank
Your inverter circuit is faulty. This controls the lights inside the screen so you can see what is happening on the LCD panel itself.
If you shine a torch into the LCD from the top at an angle you will still see the images on the screen. But with no light inside to project it outwards, it's dark.
A local TV repair shop should be able to do the reprair fairly cheap, but it's best to make a few phone calls and check they will work on an LCD monitor firstly, and secondly a rough quote.
This is a very common fault with LCD monitors.
Hope that helps =)
Apr 15, 2008 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Monitor not showing contents anymore.
Try to toggle the monitor screen, hold down the function key and hit the F8 key(usually). Wait a few seconds and try again if it doesnt work.
Dec 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
LG L226WTQ-BF Monitor Logo
181 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
