Question about Electrical Supplies
How do I wire a single light to a on/off switch
Add a comment and say what wires you have in case following answer misses your mark.
As a general rule, there is one cable that comes from breaker box.
There is another cable that goes to light fixture.
Each cable has 1 Black, 1 White and 1 Bare ground.
So you have 2 Blacks, 2 Whites and 2 Grounds.
White wires twist together and are covered by wire nut.
Black wires each connect to a different brass-colored screw on light switch. In any order.
Bare ground wires connect to green screw.
If light fixture has wires, then black goes to black and white to white, and ground to ground.
If light fixture has screws, then black goes to brass screw, white to silver screw, and ground to green screw.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Posted on Jan 03, 2011
How do i wire the gardner bender rotary switch
As with any single pole switch, there are two wires, or else two screw terminals. One is for the wire (or wires) that is always "hot", and the other is for the wire that goes out to the light fixture.
Jan 28, 2015 | Gardner Bender GSW-61 On Off Rotary Switch...
Why after installing a Pass and Seymour lighted single pole toggle switch, the CFLs in my bedroom light flicker on and off.
Is the switch wired wrong?
Does the switch have 4 wires?
Look at wiring for single-pole timer and see it it applies to your switch
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Oct 06, 2014 | Electrical Supplies
Hi, one of my room lights will not switch off - it has been working without problem for at least 3 years. I have replaced the switch with one that has been tested in another room without success. Is there...
If the switch is good, then it has to be the way the switch was wired up. (Assuming that this is just a single basic light switch and not a 2 way switch, or a 2 or 3 way circuit.)If the switch is good, then it has to be the way the switch was wired up. (Assuming that this is just a single basic light switch and not a 2 way switch, or a 2 or 3 way circuit.)If the switch is good, then it has to be the way the switch was wired up. (Assuming that this is just a single basic light switch and not a 2 way switch, or a 2 or 3 way circuit.)
You can check this site that has the instruction and pictures to show how the switch should be wired up. http://www.ehow.com/way_5233404_proper-single-pole-light-switch.html
***** ALWAYS PRACTICE GOOD SAFETY HABITS WHEN DEALING WITH ELECTRICITY! !! We suggest you cut the power at the Circuit Breaker BEFORE Dealing with the electrical wiring. *****
Oct 02, 2013 | Televison & Video
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
I have the power source in the ceiling. I want to run wire to a single pole switch to a ceiling light?
Disconnect 1 side of light. Wire nut 1 wire from switch to 1 side of wire from light. Wire nut other side from switch to light. You now have a switch inline.
Sep 09, 2010 | Leviton 104-05611-2WS 15A Decora Single...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Electrical Supplies Logo
83 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
