Question about Sony HT-7100DH System
Blu Ray player and dish network sat box both connected to Sony HT-7100DH with HDMI cables. HT-7100DH is then connected to Sony HD TV with HDMI Cable. Blu Ray sound only works if the coax cable is connected and there is no option for a coax on the sat box. The sound from both will come out of the TV speakers but not the surround speakers unless the coax is hooked up. What am I doing wrong
  • Sony Expert
  • 246 Answers
Hey my nameis Mike Houston of DISH Network and I see there is a problem with the Sony hometheater system connecting with the DISH receiver. To get the full surroundsound you want there are two different options you can use, the first is to usethe HDMI and connect the RCA cable or you can use the Optical cable for sound.If you have any questions or concerns please e-mail me back; michael.houston@dishnetwork.com.
Posted on May 08, 2011
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Tip
So you just got your new HDTV and the piture isn't as good as you thought.
There are some things you need to know when setting up your HDTV.
First off, you need to use HDMI cables to connect your tv to your cable box or you will not get HD. That being said the first thing you will find is that HDMI cables are expensive. Although you can buy a really cheapo cheap one, be careful. Make sure it can support 1080p or the max resolution your TV displays at. Some of the cheaper ones can only support up to 720p.
So you hooked it up to the cable box using an good HDMI cable and you still do not have the picture you should. There are a few things you may still need too do to get 1080i out of it. Yes, I said 1080i. Even though your tv may be up too 1080p, cable and dish networks only transmit up too 1080i. But don't worry, 1080i is amazing for cable/dish.
First thing you need to make sure of is, does your cable/dish receiver support HD? If you have had the same box for a long time, it may not. You will have to call your provider to get an updated box. If you recently got cable/dish and the box is new, most likely your good to go. Also, it will most likely say on it, HDTV, 1080i or something related to HD on it.
Now you are good to go with you box because it is in fact HD compatible. Some cable boxes may need to be configured for HD. You don't need an HDTV signal if you don't have an HDTV, and not every one does, so why send the unit configured for HD. You need to go into your cable/dish settings and make sure you set the HD set up to display in 1080i.
Okay you set the box to 1080i. There still could be some setting on the TV if your not getting the best picture.
Make sure you are on an HD channel. Make sure you do not have zoom on, and that the TV is set to display an aspect ratio that is determined by the program, or auto. Not all TV's have these settings. Likewise, some tv's allow you to select the max resolution, if this is the case make sure it is set to 1080p, the max it can be.
You should at this point have an excellent picture on the HD channels. Not all channels are HD.
Now, a few other things not worthy as a new owner of an HDTV.
a standard dvd player does not play in high def. they have a max resolution of 480p. 480p is going to look really good if its the first time you watch a dvd on an HDTV, but it can be a lot better. For around starting at $45 and up, you can buy a DVD player that can upscale your dvd's to 1080p when you use HDMI and you will get amazing picture. But for around starting at anywhere from $100 to $150 and up, you can get your self a blu-ray player that will play blu-ray disks, and give you amazing beyond belief picture, and it will upscale your dvd's.
So you got a blu-ray. First thing I can say is I hope your refresh rate is at least 120hz or better. 60hz may disappoint you with a blu-ray player.
Blu-ray can play movies in their native 24 frames a second format of which they were filmed in. However, at 60hz, you will run into a problem trying to play the movie in 24fs. now I am not going to get technical with this, just to let you know, you need 120hz or better to use 24fs. You can turn it off, but you will get blur and it will not be as smooth. As well, with most players you must enable 24fs in the settings, usually by default, it is off,
So to recap:
  • Make sure your cab/dish box is HD compatible.
  • Always use HDMI cables.
  • Check settings on cable/dish box and make sure its set to 1080i.
  • don't use zoom.
  • If applicable, make sure tv settings are at max res of 1080i
  • you need an upscaling DVD player or Blu-ray player to watch your DVD's in HD.
  • Also must us HDMI.
  • Can't use 24fs if you have 60hz refresh rate, but can if 120 or better.
  • 24s is usually off by default.
on Mar 06, 2010 | Televison & Video
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
My tv is set up with a HD dish network receiver. How do I set up a stand alone sony blu-ray dvd player. when i have tried i got good audio but the video was poor and very red.
Because this is HD to get the best picture possible, you'll need to connect the DVD player separately from the receiver. The easiest way to do this would be to connect an HDMI or component cable from the receiver directly to the TV. When you need to watch a DVD just cycle the inputs by pressing the input or source button on your TV.
Daniel Busa
DISH Network
Customer Support
Mar 06, 2011 | Proview PA-32JK1A 32 in. LCD Television
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Hdmi switcher
First check individually if they work ,then connect to HDMI switch ,then change the position of the switch if it is a manual switch or connect the cable to the dish and check the dvd works...............
May 29, 2008 | Toshiba HD-A2 HD-DVD
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
Sony HT-7100DH System Logo
195 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
