The washing machine does not spin & it has a strong smell could be clutch smell
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You will need to replace the "motor coupler" on the washer. Here is the part you will need. Below is a video to walk you thru the repair.
Posted on Jan 03, 2011
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I still need help with this.
Some models of top load washers use a clutch assembly to drive the wash basket during the spin cycle. A burning smell in your washing machine can be a result of a worn clutch, and your machine will likely be making a loud scraping noise during the spin cycle. Another common sign of a worn clutch is brake dust or shavings found underneath the washing machine. If your machine displays any of these symptoms, the clutch may need to be replaced. The clutch is normally located at the input to the basket drive and you will need to remove the cabinet and motor assembly to gain access. Clutch assemblies are often under spring tension and you should always wear protective clothing and remove power from the appliance when attempting this repair. hope this helps
May 29, 2017 | Washing Machines
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Spin cycle won't spin. Burning smell. How do I
Remove the back -- you'll see the screws to do this. Sounds like the belt or the clutch is slipping and overheating.
Charlie
Aug 25, 2009 | Washing Machines
Ge wasr311owoww profile washing machine wont spin or agitate
if the motor is spinning properly and you don't get any burning smell while the machine is in spin mode.then no need to replace the motor.only replace the clutch.this will help.motor goes bad very rarely in this units. ------------- for parts you can get it from ---- www.repairclinic.com ------- thanks.
Feb 23, 2009 | GE Profile WPRE6100G Top Load Washer
Whirlpool top loader won't spin
If you are lucky you need a set of clutches about $45. If you are unlucky you would need a transmission.
Since it spins after you help it, I am guessing clutches.
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Funky smell from working Whirlpool Ultimate Care II
run the washer then smell the motor or see if anything has jumped the tub and causing the clutch to pull harder
Mar 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
