Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have sharp aquos television and when i try to hook my playstation 3 to it, it tells me not compatible with this signal what am i doing wrong?
    Master:
  • 362 Answers
When u turn on your power to the playstaion hold till the second beep ok
Posted on Jan 03, 2011
Digital signal for my Sharp Aquos
Hi
On the TV menu did you change it from Cable to ANT?
Mar 13, 2010 | Televison & Video
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
How do i unlock inputs 1 2 and 3?
As soon as TV detects signal on input 1, 2 or 3 it will make an input selectable. Supply signal first then select an INPUT. In other words, something has to be hooked up to those inputs before you can select them.
Jan 05, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
When i connect the tv to my computer it tell me the signal is compatible
Go to the Sharp website and download the driver. That should fix it, assuming you meant not-compatible.
Let me know if that helps.
lone99star
Jan 09, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Trying to hook up mu sharp aquos lcd tv to my dell and its giving me a error saying no signal... do i need to change resolution on tv and how..
You can get that to work, it depends on how you are connected. On your owners manual there is a pc compatibility chart that shows you the maximum resolution you can use based on the type of cable you are using to connect to the television. You dont need to adjust anything with the television. That chart should be on page 30 of your owners manual, or close to it in the back somewhere. You have to change the resolution coming from your pc. To do this, you need to go to your control panel, and select display. There you will have a "sliding bar" so to speak you can adjust the screen resolution. (ex. 800 x 600). Adjust your resolution based on the type of cable you have, and check that chart.
Dec 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HP Blackbird PC Connection 'Incompatible Signal'
You may have the wrong type of DVI, I would try a different cable to hook it up with.
Jan 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Nov 24, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Sharp aquos
The screen resolution is determined by the source and not the television.  The source (e.g. a PlayStation 3) will query the television to determine which modes it is capable of and then (normally) use the highest available.
I've not had any problems with DVD players, computers, games consoles not managing to send 1080p so it might be worth checking the settings of the source device to see if there's anything you can change there.
Failing that I'd try and find a friend and borrow something from them that they know is working at 1080p without any problems - if the television still won't go to 1080p then its probably a fault in the HDMI cable or something odd with the television.
Nov 10, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
69 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
