Question about Haier Heating & Cooling
I recently purchased a haier hwr08xc7 air conditioner within the last month. I get an E1 error on the digital screen readout and it wont run at all. It seems to keep kicking the relay built into the plug end as well.
  • 190 Answers
Hello customer,
The temporary solution is to Power it ON using the remote contoller o thr air conditioner.It works.However i recommend you to lodge a service complaint to your dealer so that they would see to it.
Thank You.
Posted on Jul 09, 2008
  • Ajith Kumar Jul 10, 2008
    Please Rate the Solution.. Thank You..
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
This air conditioner has been working fine and today it cut itself off and is showing E1 in the window where the temperature usually is. I tried resetting and nothing the power on/off is not lit up either.
On Haier Ac Unis and Dehumidifiers the "E1" error code indicates a circuit failure.Only Haier Technical Service can tell you which circuit is involved. In the US & Canada call 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 09, 2011 | Haier HWR08XC7 Air Conditioner
READS E1
E1-Automatic filter clean reminder.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier HWR08XC7 Air Conditioner
I am getting an E1 error message on my unit and none of the buttons are working
E1 error code indicates a compressor sensor failure. If you're handy you may can order the part and replace it yourself. For Haier parts call 800-313-8495. Or you can schedule an in home repair by calling 1-877-337-3639 in the USA or Canada.
Hope this helps you and thanks for choosing FixYa.
WHAT IF HAIER AIRCONDTIONER SHOWING E1,AND IT STARTED GOING TO DIFFERENT TEMPERATURE WITH OUT REMOTE OR TOUCHING,
You must have a stuck button. When it is first turned on it checks the keyboard circuit and if the test fails the E-1 shows up.
Jul 16, 2011 | Haier HWR08XC7 Air Conditioner
I keep getting an E1 code and the unit will not operate.
The air conditioner must be unplugged for the automatic filter clean timer to reset.That is what the E1 means.
Jul 13, 2011 | Haier HWR08XC7 Air Conditioner
Getting an e1 code after the power went out is my ac just shot, its the haier hwr08xc7 any ideas
getting an e1 code after the power went out is my ac just shot, its the haier hwr08xc7 any ideas
Aug 20, 2009 | Haier HWR08XC7 Air Conditioner
Haier hwr08xc7 air conditioner says E1 on the digital display????
Try washing out out side coil. Check voltage when unit is running. If condencer is plugged with dirt it will cause it to overheat. Also if it will run at night when its cooler outside the load maybe too great during the heat of day to cool down and may take all night. CO may mean compressor overload . but do wash it out.worth a try. Compressor maybe failing or weak. Capacitor maybe going bad. Hard to trouble shoot with out seeing it.
Jun 23, 2009 | Haier HWR08XC7 Air Conditioner
Heating & Cooling Logo
311 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
