Question about Vacuums
Do you sell replacement parts for a Tatung TUH-750HA Ultrasonic Humidifier?
Need manual for delta ultrasonic cleaner.....not in box when purchased from aldi
Hi.
Here all the documentation available on the web. If this is not enough contact Aldi to get a replacement booklet:
Model: 334.150
Data Sheet
Catalog Page
Model: 334.D80H
Data Sheet
Model: 334.010
Catalog Page
Data Sheet
Model: 334.080
Data Sheet
Catalog Page
Jun 10, 2011 | Vacuums
No matter what humidity setting humidifier is on it no lomger collects any water model# maytag m7dh6582a*a
Most likely the compressor is not running. This unit has been in service for some time as most of the replacement parts have been discontinued. There are some common parts that are generic that can be found like the capacitor and PTC relay & overload but this would require someone troubleshooting the problem of the compressor not running and determining which part has failed. Then to get COMMON parts it would be a matter walking into an apliance parts supply with part in hand to find them. If the controller has failed.. it is not available. If the fan motor has failed it is not available. The usual failures are as stated above, capacitor, PTC relay & thermal overload. Some one will have to remove the cover of the compressor terminals measure input power, inspect the PTC relay, thermal overload, wiring, terminals on the compressor, then measure the compressor windings for resistance and grounds to the case of the compressor.
If one of the common parts that are generic has failed you can repair this unit. If the controller, compressor or fan has failed your looking at replacing the unit.
Thanks for choosing FixYa,
Kelly
May 16, 2011 | Vacuums
How can i get a replacement part for my vicks v3500 humidifier?
"How can i get a replacement part for my vicks v3500 humidifier?"
Knowing which part you're looking for would help immensely.
Aside from that, you can check here:
http://www.appliancefactoryparts.com/humidifiers/kaz/?gclid=CJOU4qTV4KgCFUMUKgodYmwIDQ
or here:
http://www.kaz.com/kaz/humidifiers/products/vicks-v3500-replacement-tank-m-gc.7206/
or just "Google" for the specific part you need.
May 11, 2011 | Vacuums
I am trying to find a replacement water tank cap for a Vicks V4450 humidifier. I dropped the cap and broke it on the edge. Everything I see on line does not say it will fit the V4450. My e-mail address is...
http://pg.custhelp.com/app/ask This is a link for Vicks online help section. I'd shoot them an email and simply ask if they can send or sell you a new one. Have the model number available.
http://www.pg.com/en_US/brands/health_wellbeing/index.shtml Here is the link for Proctor and Gamble who is the parent company of Vicks.
Good luck !
Mar 02, 2011 | Vacuums
I have a very old Soundesign Ultrasonic Humidifier. Model 1866. I need a water tank cap. This cap has a plastic pin in the middle of it as well as a rubber gasket type thing, this helps control the flow...
just realize its an old post. just throwing mine out i would have sent u the cap. mine stopped shooting mist out cap is good oh well. linda c
Jan 01, 2011 | Vacuums
Looking for plug for water go in s3501
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
Dec 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I misplaced my manual for my sunbeam model 1128 warm mist humidifier and would like to know how to clean it....there is a white powdery stuff coming out of the base, how do i get rid of this....or could a...
the white powdery stuff is minerals, use a vinegar solution to warm water 1 part vinegar to 4 parts warm water. let it soak in the humidifier overnite or during the day and rinse with warm water. You could also use clr using bottle directions.
Dec 03, 2010 | Vacuums
My shark steam mop handle broke, is there anyone who sells the replacement parts for these?
i know of a great site that sells all kinds of shark parts check it out
http://stores.ilikenew.com/-strse-Replacement-Parts/Categories.bok
Nov 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
100 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
