Question about Jack Lalanne Power Juicer 250 Watts
How do you open the blade on the jui3567cer - Jack Lalanne Power Juicer 250 Watts
    Problem Solver:
  • 9 Answers
Open the blade? you mean get it out for cleaning? just pop it out by putting a knife or back of a spoon under it and gently pry it up in a few places. works like a charm, been doing it for 5 yrs
Posted on Jan 09, 2011
I need a cutter blade parts no 015180. Can I pay for it on the net?
You can buy it from Waring or Omega, same blade.
Or, just google Acme juicer parts. $20 to $30. Look
out though, found new blade increases vibration. You
can also sharpen old blade by slightly drilling into
each burr on the blade with a small drill bit. Been
using the same blade for several years.
Jan 28, 2011 | Acme 6001 Juice Extractor
The blade to my Jack LaLanne juicer was screwed on without the filter in place. Now the blade spins but will not come off. How can I get the blade off?
it came with a blade removal tool,, if not take a dish towel and place it over the blades ,push down and turn it will come off
Oct 19, 2010 | Juicers
I cannot remove the blades from the shaft. This juicer has been in storage with all the attachments in place. I was able to pry it out about an inch or so but can't get it any further. Is it safe to use...
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
Sep 30, 2010 | Champion G5NG853S Household Juice...
I do not know how to clean and take it apart
I did some research here on Fixya and this is what another expert had to say.........pull the metal bar forward and down to open up into the blade compartment. your juicer should have come with a handle type key wrench thing that you stick on top of the blades into holes to unscrew blade holder, while unscrewing that hold the blade still.
Hope this helps you......best wishes.
Oct 05, 2009 | Jack Lalanne Power Juicer 250 Watts
How do you take apart the jack la lannes juicer for cleanning
I had the same problem because I bought it used. After reading that I needed a key that fit in the holes I used a pair of chop sticks and it twisted right off.
Sep 15, 2009 | Jack Lalanne Power Juicer 250 Watts
The pusher to push the food into the blade is coming into contact
The blade maybe was not screwed in right. Screw out the blade using the blade tool and screw it back again making sure it is screwed in and fitted in right. Do not tighten too much. It breaks easily.
Jul 10, 2009 | Jack Lalanne Power Juicer 250 Watts
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Jack lelane juicer-CL-003AP
You need the crescent tool to remove the blade. You insert tool into the blade and push down while turning. Try the official Jack Lelane Juicer website where you can order for about $20.00
Aug 20, 2008 | Jack Lalanne Power Juicer 250 Watts
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Jack lalanne power juicer
I seem to be able to put the crescent too in but the blade just spins and doesn't seem to be connecting to anything to pull it out. Talk about frustration!!!!!!!!!!!!!!!!!!!!!!!
Jul 21, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
