Question about Hyundai Heating & Cooling
Unit wont turn on and there is a triangle icon on the remote. remote is on but wont responed hyundai unit
  • Hyundai Master
  • 17,130 Answers
Please remove the battery from the remote control and keep aside for about 15 minutes. Now make sure that the A/C unit mains power is switched OFF. Replace battery back and switch on power. Use the mode settings to change the display to A/C cool as the triangle should disappear. Make sure that the temperature setting is below the room temperature as the A/C will not turn on unless the thermostat is set to a cooler setting. So reduce the temperature setting to about 22 *C.
If the unit does not start up - the compressor not starting but the fan seems to work, allow it some times as an earlier shut down while the machine was working would force the control processor to delay the start. However if the compressor fails to start even after 15 minutes then the unit must be checked for a fault in the wiring to the compressor, fault in the relay unit or failure of the compressor motor. A good electrical voltage check must be made to confirm the matter.,
Posted on Jan 03, 2011
Relpaced the control module in my Hyundai 2002 myself, now the remote wont work to lock/unlock the doors. should I have done something different
did you matched the oem numbers with the replacement unit? if not you may have to bring it to a dealer to be re programed. or just live with out remote, it is expensive and they may want you to buy another unit, good luck!.
Oct 14, 2013 | Hyundai Motor 2002 Sonata
Panasonic TC-L37X2 will not respone to remote
It sounds that the infrared sensor inside the TV is faulty. Replace it and try.
Will look somewhat like these, and can be located just behind the infrared sensor window. You have to open the TV to access it.
Jun 07, 2013 | Panasonic Televison & Video
32" samsung tv wont turn on standby light stays red but it wont change with remote or by preesing it
Tries unplug,replug the tv back like an hour later.The tv,now will reset itself back to the factory setting.The tv should work now.If not,this problems,usally the cause it by the power supply board not responing and giving the the right voltages to the tv anymore.Tries websites like Shopjimy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 22, 2010 | Samsung LN32A330 32 in. LCD TV
MY controler wont turn on when fully charged and it does responed to the ps3
At the back top of the remote behind the 4 red lights there is a tiny pin-hole. With your PS3 on, press the big PS button on your remote, then push the button inside this little hole; a pencil lead may work. This is the only time you need to do this.
Good luck and please give me a good rating if i've helped you.
Don
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
My mini split does not run
Check that you are on the correct mode setting. Open the remote and press the mode button (the one with about four little icons, star, teardrop, triangle and sun) until you get to the mode you require. If cooling required, select the star or crystal, if heating required select the sun (circle with little lines)
Mar 06, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Red light came on and air conditioner will not turn back on
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
Jan 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
My printer icon on taskbar has a yellow triangle and wont print a
If you haven't already done so, might I suggest you uninstal the printer and re-instal as per the instalation manual.
This normally resolves these issues. Also make sure this printer is set as your default printer.
Hope this helps
G
Jan 13, 2009 | Dell 922 All-In-One InkJet Printer
Reset modul
if the batteries are fresh in the remote try unplug the unit for two minutes and retry the remote let me know if this helps
Jan 11, 2009 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top Hyundai Heating & Cooling Experts
cwradio73
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you a Hyundai Heating and Cooling Expert? Answer questions, earn points and help others
