Question about DSC 8 Zone LED Keypad
Just moved into new house. Plugged in DSC PC1832 to power outlet. Keypad beeps every 3-5 seconds and yield sign is lit. How do i keep it from beeping, and only beep when doors open?
    Scholar:
  • 44 Answers
This means there is a fault on the panel, either something very benign ( like the system clock is not set or a low system battery ) all the way up to a major configuration or communications problem. You can press * + 2 to see the troubles on the panel. If it is the system clock, you can set it from there and be home free. It is probably a good idea to have the local alarm company come by and do an inspection and test, though, as the communications may be down ( last tenant ended the monitoring contract, phone line may be disconnected, etc.) and you probably want to change the user codes.
Posted on Mar 07, 2011
My DSC house alarm has no power to keypad or sensors what's wrong
Either there is a fuse blown to.thevaux power or the wire has come loose from the terminal or there is a broken wire. Lastly have you checked to see if the transformer is still plugged into the outlet?
Dec 14, 2017 | DSC Home Security
The fault warning sign is beeping when i open the fridge door
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Jan 20, 2016 | GE Refrigerators
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Keeps beeping, but not overfilled
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 15, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
How to reset pc3000rk keypad
go to the following link below and see the door chime setting. switch it off as instucted in the manual and it should sort out your problem.
http://www.myalarm.com/manuals_prog/pc3000p.pdf
Oct 25, 2013 | DSC Pc3000rk Pc Classic Pc3000 Rk Keypad...
BeverGE COOLER KEEPS BEEPING
Apr 17, 2013 | Beverage-Air Refrigerators
I have a Lynx system with a 5828 wireless keypad that I have connected a 5v transformer to it to keep the keypad lit always. The keypad does not stay lit always and it keeps going to sleep after 10...
It sounds like your 5V transformer isn't working. It could be the outlet it is plugged into isn't working, or the outlet is on a light switch that is turned off, or there is a problem with the keypad itself. The user manual says:
"AC-Powered Operation: When powered by the
optional AC adapter, the keypad remains active at all
times. If AC power is lost, the keypad reverts to
battery-powered operation until AC power is restored
On AC powered units you can get the status by viewing
the display."
The only way I know of to keep it active is by using the transformer.
Hope this helps.
Mar 22, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
User manual for PC1832
For the user manuals please see the following link:
PC1832
http://cms.dsc.com/download.php?t=1&id=10747
PC9155
http://cms.dsc.com/download.php?t=1&id=11453
You specified both the PC1832 and the PC9155.
Mar 03, 2011 | DSC Alexor 2-Way Wireless Panel - PC9155
DSC 8 Zone LED Keypad Logo
601 people viewed this question
Top DSC Home Security Experts
Steve
don1956
Level 1 Expert
Tom Chichester
Are you a DSC Home Security Expert? Answer questions, earn points and help others
