Question about Miller Syncrowave 200 Tig Welder Cover 300059 New
My miller syncrowave 200 shows a code 11 or code 12 error message. What is that about?
  • 7 Answers
SOURCE: Miller TIG Welder Syncrowave 350XL has no digital read out...
it's free for you to download.
http://www.millerwelds.com/products/tig/syncrowave_350_lx/
Posted on Mar 21, 2009
CarlGehrke
  • 169 Answers
SOURCE: miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Posted on Jan 26, 2009
SOURCE: No power to receptical... on syncrowave 350 Miller
I Have Lincoln Welder Weldanpower 250 G9 PRO IT will srart then die
Posted on Mar 13, 2009
  • 225 Answers
SOURCE: Miller Syncrowave 180 SD seems to need a control
go to local welding store they should be able to order one for you.
Posted on Jul 05, 2009
  • 225 Answers
there was a place on the east coast that reworked pc boards but no garentee on boards,I would pay the price,even though its going to hurt the wallet.
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
    Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
    Nov 21, 2013 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    Can't set up syncrowave 351 to tig weld aluminum. I can not seem to get the settings right to melt the aluminum. It just leaves a bif spot on the aluminum plate.The plate is about 1/4" thick and...
    Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
    Oct 08, 2011 | Miller Electric Manufacturing Electric...
    I am throwing an error message HLP what is the problem
    Hi:
    After the HLP should be a number on it. What number is showing you?
    Jul 30, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    Miller syncrowave 250 tigrunner with gas flow
    Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
    Nov 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    Syncrowave 180 sd. I was welding when it shut
    Sounds like a bad thermister on the rectifier or a bad control board.
    Aug 12, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    Miller Syncrowave 200 Tig Welder Cover 300059 New Logo
    383 people viewed this question
    Top Miller Welding Tools Experts
    Kory Ronning
    hubiam
    hubiam
    Level 1 Expert
    John Trevino
    Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
