Question about Dryers
My washer is saying SUD and will not clear or do anything. it was in mid cycle
    Top Expert:
  • Dryers Master
  • 9,472 Answers
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Posted on Jan 03, 2011
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sears kenmore washer 110.42822200 error code sud
SUD- Suds lock (Overdose of detergent detected during the wash cycle, or the actual brand is a non HE type)
The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Possible Causes / Procedure
• If too much detergent was used:
A. Run the unit through a Rinse/Spin cycle.
B. Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent. If the problem persist, follow this check list below.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Press PAUSE/CANCEL twice to clear the display.
Dec 07, 2009 | Kenmore Washing Machines
Whirlpool duet washer has stopped and the LED indicator says sud
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 09, 2009 | Whirlpool GHW9200L Front Load Washer
SUD message appears
My manual says that Sud means that you are using too much soap. The washer will say this mid cycle until it gets rid of the extra "suds" and should then resume the cycle. If it doesn't, then you have a different problem.
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My machine is "froze" and won't let my clothes out!
Just let me know what the results are, and if any error codes appear. The "SUD" error can be caused by obstructions in the drain pump and/or using too much laundry detergent.
Jan 14, 2009 | Kenmore Elite 45986 Front Load Washer
Wont start and says "SUD"
yes I can the suds is from too much soap it will go thru a flush cycle and should go away after 4 min of opert. let me know if it does not clear you may also get a LD code on the machine to clear press cancel twice
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Dryers Logo
82 people viewed this question
Top Dryers Experts
