Question about Kenmore Washing Machines
Water temp setting of warm gives cool water - Kenmore Washing Machines
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.If you're sure the machine isn't working the way it used to--or should--try these tests:Is the hot water turned on? If not, turn it on.Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Posted on Jan 03, 2011
My remote controller of the split type machine have two keys such as 'TOO COOL ' AND 'TOO WARM' . May I get the information about functioning of these keys in which situation use .
If you press Too Warm, temp will automatically 3 degree goes down as setting temp. and same when you press Too Cool, set temp will raise + 3degree.
In your remote set temp is 24 and you press Too Warm, set temp becomes 21 and same in Too Cool will become 27. It's normally in O'General a/c May be 2 differ in other units instead of 3degree. Thanks, and helpful?
Jan 21, 2011 | Heating & Cooling
The fridge is too warm (15) but the temp. is set at 4. The temp. indicator sometimes shows 2 but the temp. inside the fridge is still 15
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
My Kenmore Elite total care system gets stuck on the Pause Cool Down step and then again on the spin setting. It doesn't even drain after rinsing.
The washer has a temp sensor for the rinse cycle , so just set the temp to warm water and it will stop getting stuck, because it wants the water to be warm when it rinsing ,ok hope that helps you! Ericc
Jul 03, 2010 | Kenmore 24032\24036 Top Load Washer
Leaking Antifreeze, overheating and blowing cold air through vents when temp is set to warm
wow bro thats kind of vauge star lokking for leaks around common places radiator hose clamps water pump if visible ( no clue what car you have)
May 02, 2010 | 1999 Dodge Durango
WPXH214A Water Temp: Any selection that has Warm
The cold side of the water valve is either clogged or not opening. Take the cold water hose off of the machine and see if the screen is clogged. If clean you may need to replace the water valve.
Feb 25, 2010 | GE WPXH214A Front Load Washer
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Cool water comes out on warm water setting.
The water that is coming from the hot water pipes is likely not hot because it cooled down while sitting in the pipes. We had similar issues with hot water not being ready when our appliance needed it. We heard about Redytemp from our plumber. We have yet to have anymore problems with having hot water when needed.
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
