Question about Dishwashers
Dishlex dx302 heating element - how do I find it and replace it??
kevin000
  • 1847 Answers
SOURCE: i have a dx302. its not heating the water or drying.
download this manual...
http://epubl.luth.se/1402-1617/2006/118/LTU-EX-06118-SE.pdf
Posted on Aug 22, 2008
funkyjacob
  • 76 Answers
SOURCE: dishlex dx302 - not heating
If it is the old model about 15 years old (i own one myself) it is the water inlet it may be leaking.
I had the same troubles and i installed a new pipe on the dishwasher and now it heats fine. All you need to do is get a new pipe (you can get them from the dump) off of an old dishwasher and put it on yours but make sure it doesnt leak first.
If you have more questions please dont hesitate to ask im more than happy to help
Jacob McNamara
Posted on Dec 02, 2008
SOURCE: My DX302 dishwasher wont heat the water, the
The heater relay n/c leg had melted the solder off the board, I re soldered the leg laying it on a bit thicker. cheap fix.
Posted on Jun 24, 2009
SOURCE: i have a electrolux dishlex dx302 that will not
Yes I had the same problem. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Posted on Aug 05, 2009
SOURCE: user manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Posted on Oct 29, 2011
I have a dx302. its not heating the water or drying.
Aug 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Why does my dishlex dishwasher DX302 not heat
Dishwashers require a gap for air flow all the way around, not tight fit.
If it works when out but not installed, check the water pipe is not kinked and the door switch is working properly.
Sep 07, 2017 | Dishwashers
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
Hi I have a Dishlex DX302. After an intense wash it leaves a film of scum / powder on the dishes and sometimes does not wash properly. I have tried using various soaps and also tried to use a dishwasher...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
User manual for electrolux dishlex DX302
Nov 12, 2009 | Electrolux Dishwashers
Dishlex 302 water not heating
My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
Jun 26, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Problem with dishwasher detergent dispenser
we should replace the whole dispenser otherwise it can be leaked
Mar 23, 2008 | Dishwashers
Dishwashers Logo
1,184 people viewed this question
Top Dishwashers Experts
