Question about Canon MV730i Mini DV Digital Camcorder
How to reset Canon MV730i ?
I have a problem with CCD (dark screen with menu in "camera" mode). II dissasembled camera, unconnected flex-cable from lens-assembly and
.. ops... my camera went to "safe mode", i think. I connected all cabels - switched my camera on - no resuts (camera didnt switch on - dark screen, no sound). i tried - power off and battery off - no results.
How to reset this stupid device?
When i try to take photo the the LCD screen is blank. Theis happen after i changed the battries. I can review previous photos on the screen however when i go the take Photo mode the screen is dark.
It is ccd imager chip failure problem that need to be replaced.
Canon offers free of cost ccd imager chip replacement for same problem in many models, click Canon Support for details to get free of cost repair offer.
Thanks.
Jun 04, 2011 | Canon PowerShot A610 Digital Camera
My canon mv730i will not display images on the screen or view finder when taking picture or video;s
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 28, 2010 | Canon MV730i Mini DV Digital Camcorder
Picture is dark, flashes of light when in camera mode. cant make out images on screen. menu's seem to work. boots up fine.
This is known problem of ccd imager chip failure in DSC-T1 camera, ccd imager chip will be replaced to get correct live view in camera mode.
Let me know if you need ccd imager part number info.
Aug 20, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Auto function does not work - photo's are dark.
Go into the menu and scroll to "reset"...follow the on-screen instructions.
Nov 23, 2009 | Canon PowerShot SX110 IS Digital Camera
Blank screen after turning on won't allow reset
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status.
Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Aug 04, 2009 | Canon PowerShot SD100 / IXUS II Digital...
LCD screen stays dark
I have the same problem and very frustrating! The camera turns on by won't show anything (totally black) in the camera mode. The menu still works. If I take a picture the display is black and shows black for it in the display mode model as well. Tried everything that I can think of but nothing helped. (Taking out the batteries and reinstalling, switching the mode from display to camera and back, stepping through each mode option, stepping through each menu options). The last option worked once but won't work later on. From this forum this seems to be a common problem with this camera. Guess won't buy another camera from Canon any more. I bought a camera (non-digitals SLR) from Canon before and was very happy with it for over 20 years. Thought Canon had the right thing in camera. This problem made me think twice when I buy another camera in the future. Perhap Canon is not as good as I thought. By not fixing the known problem, they are ruining their reputation.
Jul 27, 2008 | Canon PowerShot A610 Digital Camera
Canon powershot a520 problem
Try to see if you can connect the cable to a TV and see if it will do the same thing.
Example: camera - cable plug - to Input of TV.
Jul 23, 2008 | Canon PowerShot A520 Digital Camera
Canon S2IS Black Screen in Auto mode
sir, ur problume related to CCD u replace CCD
Apr 01, 2008 | Canon PowerShot S2 IS Digital Camera
CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Oct 02, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Camera records no video
Hi John, my 730i is driving me mad too http://www.dpreview.com/news/0510/05100602canon_ccdproblem.asp this might help us both. Steve
May 01, 2007 | Canon MV730i Mini DV Digital Camcorder
Canon MV730i Mini DV Digital Camcorder Logo
69 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
