Question about Music
Where can I get a power cable to a Yamaha Digital Piano Model YDP-223
  • Music Master
  • 5,603 Answers
The cord is the same as the standard ones used on computers and many devices. You can get one at most any computer store, but here is a HINT: You can often find them at thrift stores and computer recycling facilities.
Posted on Jan 03, 2011
I Need a power board for a Yamaha YDP-121 digital piano
Is the board missing? If not, just repair the board. Here is link to manual close to your unit:
http://elektrotanya.com/yamaha_ydp-131_131c_sm.pdf/download.html
Scroll down to near bottom and wait for "download your manual" in lower right corner. Click to download. This is the 131 model but should be VERY similar to your unit.
Mar 04, 2013 | Music
Ydp 223 some keys are starting to stick to on the downstroke when not struck with a perfectly vertical stroke. varying degrees of affliction. instrument 2 years old thanks for any help
Yamaha keyboards can be prone to sticking keys due to the rear part of the key cracking around the return spring - if this is the case the only solution is replacing the affected key modules. However this problem generally only occurs with long term use by very physical players.
Otherwise the problem may be caused by a build up of dust / fluff between adjacent keys - try raking out the spaces with a thin piece of fairly rigid plastic (maybe a credit card might work?)
Feb 24, 2011 | Yamaha YDP223 Digital Piano
Digital Piano has sticking key
Typically LOTS of screws... concentrate on those around the edge. USE GREAT care and force nothing when removing the cover...and great care of cables between the cover and the base. Mark the cables so you remember the direction they attach.
When you get edge screws out, then gentle lift and see where it seems to be held...
Some of these synths have 50 to take out to get apart. MOST are in plastic bosses and keep track of the size and length as you can put too long a one in the wrong place and crack the boss.
I use a compartmented plastic tray to keep the screws in order.
Jan 06, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
My Yamaha YDP-121 digital piano has a key that is slow to pop up once pressed...the key will still produce a sound but the key becomes "sticky" and stays pressed, sometimes requiring manually lifting the...
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
Nov 29, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Yamaha ydp-121 88-key piano. It has 3 keys that are sticking. Any ideas how to fix it?
I wrote up and photographed for my similar YDP, see solution 2 under this post:
http://www.fixya.com/support/t8881187-1_key_not_spring
Oct 20, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Sticky Keys for Yamaha Digital Piano YDP-121
have you tried using the can of air. you can get it at almost any drug store walmart or kmart. just spray the can of air between the keys and they should become unstuck.
Dec 07, 2008 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
82 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
