Hicon 42" plasma tv won't
gilheero
  • 207 Answers
SOURCE: High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Posted on Feb 05, 2008
SOURCE: 42 inch LG Plasma TV - Lost picture
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
Tech4lfe
  • 42 Answers
SOURCE: Parts for Maxent 42" Plasma TV
The TV was made by LG. You should be able to google an LG distributor or try ebay. The 953 is readily available but the 917 may be hard to find. Won't be cheap for new ones, around $350-$400 for both unless you can find used.
Posted on Mar 06, 2009
SOURCE: tv red blink no start42 plasma philips
Thank you for the help. I actually changed the whole main power supply board and it still did not fix the problem. When I put the new one in, I had the tv on for about 3 hours and then I shut it off. No sooner did I get it back up on the wall and the problem started all over again.When I pulled the original board, the caps all looked fine so I am not even sure the board is bad. Problem is there is no one around me to test it. I am not going back to the same shop that already told me that it was a bad main power supply board. Any other suggestions?
Posted on Jun 25, 2009
dsacco86
  • 1077 Answers
SOURCE: I have 42 in ilo plasma tv. I can turn tv on but
Most likely the TV has a Mother board related issue. Your TV is just like a computer. When it freezes up, nothing responds and you have to pull the plug to turn it off.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part or replace the whole circuit board. The Service Manual will give you circuit diagrams, test points, and part# lists.Service manual cost about under $20. Most cases the new part cost less than $15. New circiut board, depending on type, may cost about $125.
I hope I shed some light on the subject for you.
Posted on Jul 08, 2009
Why is TV flashing and not turning on. made a sizzle sound
dead tv
take it in for a diagnosis
plasma tv units are very costly to run so consider the quote and get an LED unit that is the cheapest unit to run
Nov 24, 2017 | Televison & Video
How do you stop the hicon hd plasma tv from jumping
Picture jumping is usually caused by its main digital processor [Tuner VIF] board.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 18, 2015 | Televison & Video
Why won't my Panasonic 42 TCP42S30 42 Plasma TV turn on.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service
technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Panasonic 42 TCP42S30 42 Plasma TV
42 " panosonic plasma model th-42px6ou keeps
There is an energy save setting on your controls. Turn that off if you don't want tv to keep turning off while you are changing inputs. Hope this helps.
Oct 16, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Hicon (1903SD) TV switches itself off every few minutes
try tilting it or laying it flat first and see if it stays on
Jul 03, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have a 3 yr old Panasonic 42" Plasma
it might be coming from the actual audio/video source. try hooking up a dvd player or gaming system and see if it still does it.
Jul 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
