Question about Frigidaire Refrigerators
PART for model# frt18lrhdo
Cannot find this model in your database. It's a bottom door shelf bracket that snaps into a fixed arm.
edmar42@optonline.net
    New Friend:
  • 160 Answers
I think this could be the page for it
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=114667
Posted on Jul 09, 2008
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
Dishes do not wash. First we were having problems with the top rack not getting clean and now the bottom is the same way. Any suggestions would help. Thanks in advance.
Your spray arm jets are probably clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
The upper spray arm receives water pressure from a tube that runs up the back of the machine on the inside. If the connection has been knocked out of line, the water can't flow through the tube to the spray arm. My kids used to knock ours loose when they loaded the lower shelf. Pull out the top shelf and see if the plastic connectors are in place. If not, snap them back on the shelf supports and this should align the tubes.
One more thing: the bottom of the door..on the INSIDE of the machine.It's amazing how much "gunk" settles and accumulates under there. I use an old toothbrush, moistened in soapy water to scrub the underside of the door. Then pour hot water on the area. Next run a regular cycle with NO items in washer and use 1/2 cup white vinegar...no detergent.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 22, 2011 | Dishwashers
Neither of the arms are spinning water
Jul 21, 2011 | Whirlpool Dishwashers
My LG dishwasher soap dispenser does not empty entirely and leaves a residue on the door. It also doesn't seem to be cleaning as well as when it was new. It's about 2 years old. I was using a gel...
Make sure you're not loading the dishwasher with large items close to the soap dispenser. These can block the action of the dispenser door. Also, be sure the water temperature is 140 degrees for the best cleaning efficiency.
Another thing may be that your spray arm jets are clogged.
Jul 21, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Displays check document, nothing there
The paper path arm on the doc feeder popped out of the bracket. You need to remove the two sides of the ADF main feed unit, this allows you to open the unit further. take out the two scews holding the bottom gray plate on, you will find the actuator laying next to the bracket on this gray plate. snap it back into the bracket and reassemble. this happens when a misfeed is yanked out of the feeder.
Mar 30, 2010 | Canon LaserCLASS 510 Printer
Frigidaire GLD2445RFS0 dishwasher has developed a door leak
Make sure the lower spray arm ends (there are 3 arms) are snapped together all the way. One of ours had come apart and was spraying water out the end of the one arm. It was enough to "spurt" water past the plastic gasket at the bottom of the door. I snapped the arm back together and BINGO. Free fix.
Sep 29, 2009 | Frigidaire Dishwashers
Door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Dec 20, 2008 | KitchenAid KUDC25CH Dishwasher
Oven door closure
I had the same problem, the door will come off by opening it partially and lifting it up off the hinge brackets. Be careful, because the brackets are spring loaded and will snap shut when the door is removed. You will find a hinge pin with a spring clip at the bottom of the hinge. It's likely that the spring clip has come off of one of the hinges and the pin fell out. You can find the drawings and part number(s) on the "partsdirect" website using your model number, and even order them there.
Jun 27, 2008 | Ovens
I have the same problem with dirty dishes on the top shelf and the utensil baskets
Dump the Kenmore on the seller's doorstep - when the place is full of customers!!
Dec 27, 2007 | Kenmore 24 in. 16264 Built-in Dishwasher
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
