Question about Maxtor Shared Storage II (S01R320) Hard Drive
When I power up my Maxtor storage drive, the yellow light remains on (no green light). I cannot turn it off by holding the power button down. It is also making a high frequency noise.
bsrjth
  • 270 Answers
SOURCE: Maxtor Personal Storage - beeping noise
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
Posted on Dec 03, 2007
  • 11 Answers
SOURCE: Maxtor Basics Personal Storage 3200
I had a similar problem with my pc( OS=XP SP2) with the same external drive model. I was able to solve it by downloading and installing WindowsXP-KB908673-x86-ENU Hotfix Package from Microsoft Corporation. I hope it works for you.
Nelson
from P.I.
Posted on Jul 11, 2008
SOURCE: Maxtor 3200 power indicator lights but computer won't recognize
I had the same issue. My PC would not recognize the external Maxtor 3200 hard drive, but the light was on, although feintly. Here is what I did. I went out and bought another Western Digital 500 GB USB hard drive, knowing that it probably had the same power supply. Got home and plugged the power supply into the Maxtor 3200 and immediately my Windows XP immediately recognized it and the drive was perfect. I checked with Radio Shack before coming home and they have the power supply needed there, with multiple choices on the size of the power input. The problem was the power supply cord. Now I have the Maxtor with all my media files on it and another that I will transfer files to as a backup
Posted on Mar 23, 2009
  • 85 Answers
SOURCE: Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Posted on Jul 01, 2009
bhagyavichar
  • 414 Answers
SOURCE: maxtor external hard drive fell on floor (maybe a
yeakis..!!..
itz probably not normal anymore..it do happen while boot up or when hdd gets power..hdd consists of one or more solid n heavy platter(s) like gramophone media/disk in miniature, which is spinning at more than 7200+ rpm just on a single pivot which is thick just around a dot pen's nib..there is one lens each on both side of the platter of abt 1mm probably..and the whole assembly do function somewhat alike gramophone....
nw u cn understand how highly balanced they r..due to time, illegal shut down, moving/shacking/thud/shock to the hdd while in activity, may cause damage to it..and the first n common symptom is either no activity or 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..!!
do claim warranty..report as hdd dead..don't tell itz physically damaged..
try contacting ur system admin/vendor without delay....
Posted on Nov 16, 2009
Canon i9900 printer. Yellow light remains on. Does not blink. Green light will not come on. Anyone know what part needs to be replaced?
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Canon I990 InkJet Photo Printer
Hello. I get 8 yellow flashes indicating the ink
Or try
7) Print away!
Oct 07, 2009 | Canon i950 InkJet Photo Printer
Solution:
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Canon S400 lite binks 6 times won't print.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Dec 27, 2008 | Canon S400 InkJet Printer
Maxtor 3200
There is a troubleshooter that describes steps for these symptoms on Seagates Knowledge Base website.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=188697
Aug 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Wont turn on?
The external have a problem it need to be repaired or just buy new
Oct 28, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Maxtor Shared Storage  II (S01R320) Hard Drive Logo
311 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
