Question about Ovens
The self cleaning wont work and the door does not lock.
  • Wallace Le Sauteur Jan 04, 2011
    Thanks dor your answer. Both elements works good. The bottom one looks ok and we put the oven at BROIL and the upper one is working ok also.
    To me the problem seems to be in the locking rod. When we start the cleaning process, the locking rod only turns about half way and does not lock the door. We can hear a noise like a motor trying to turn the rod. I even tried it by holding the door button with my finger. And, we can hear the same noise wit the locking rod trying to turn to be in locking position. Anyway, the door does not lock and the cleaning process wont start.
    The stove is INGLIS and Model No: IJP85800 and it is self cleaning. Never did that before!
    Thanks
    Wallace
  • Ovens Master
  • 17,970 Answers
There are a number of different things that you will need to consider. There are lots of different features on various ovens including the self cleaning feature. A self cleaning cooker is a wonderful feature, however this doesn't mean that it will always work. If the self cleaning feature doesn't work correctly then you will need to find out exactly what's going wrong.
Checking the Door
For the self cleaning function to work correctly you will need to ensure that the door shuts properly and latches properly. If the door doesn't shut properly then this will cause problems with the self cleaning function.
The catches on the doors can often be adjusted very easily to change how the door shuts. If the door is not shutting properly then this could be a result of the door catches not being set correctly. Using a screwdriver you can adjust these catches
If the door has dropped as a result of gravity then this can be corrected by adjusting the door hinges.
Testing the Element
Another thing to check is to ensure that the ovens element is working correctly. The element is what heats your oven and will also help clean your cookers door. If the element isn't getting up to the right temperature then this will mean that the cooker won't clean properly.
Unscrew the element and disconnect all of the wires. The element can then be removed from the cooker and a multi meter can be used to check the resistance of the element. The element should have a resistance of between 20 and 40 ohms if it's healthy.
If the element is infinitely resistant then this is a sure sign that the element is faulty. Replace the element with the correct model for your oven and check that the correct element for your cooker is installed and used.
Testing the Temperature Control
The temperature controls will control the thermostat and regulate the temperature of the oven. If this is not working correctly then this will cause problems with the self cleaning function.
Test the temperature control by adjusting it and checking that the temperature inside the oven is controlled correctly.
Testing Oven Selector Controls
Sometimes the oven selector control can also stop working. If this is the case then it will often prevent the oven door from being cleaned correctly.
Attempt to turn the oven selector controls and check that they are controlling the oven correctly.
Cleaning the Oven
Once you have fixed the problem with the oven you might then need to clean the oven to start off with. The ovens self cleaning feature is only designed to clean small amounts of grime off the door continually. Starting on a heavily soiled oven door could be impossible, which is why you might need to start the cleaning off yourself.
I suggest read your owners manual again, just to make sure your doing it right. If the tests and owners procedure dont work; if you follow the instructions word for words, and you can not program it properly, it sounds like a defective Electronic Range Control.
Keep us updated.
Posted on Jan 04, 2011
  • ZJ Limited
    ZJ Limited Jan 05, 2011
    Its possible that your prboblem is more simple that you'll believe; first check out this tip-link... Self Cleaning Oven Problem
    Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up ). Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean ).
    If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
    Send us your comments.
  • ZJ Limited
    Also, suggest try now, you don't know if there is a reset button to open it or if you have to bust it
    open to release contents inside!
    STOP
    Try this reset feature and see if I can help you open it.
    1.Turn everything of on the range and oven.
    2.Go to the breaker and turn it off for 5 minutes.
    3. Turn the breaker on.
    Now lets see if this procedure reset the system and released the oven door lock!
Self cleaning
There is a SAFETY INTERLOCK, if you opened it then locked... Is that what you said? It can not clean if the door is not locked.
If you unplug the stove and this will give it a reset. but you may have done some mechanical damage that you will have to inspect to see what it is doing. Is the Locking handle working properly? Is anything jammed ? Ect... Look at the Mechanical components first...
Mar 01, 2014 | Frigidaire Ovens
BOTTOM DOOR WONT LOCK FOR SELF CLEANING. The motor is making a noise but lever doesn't move
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Oct 21, 2010 | GE Profile JTP56 Electric Double Oven
Self clean cvode F9
Hello there:
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
replace parts as necessary
May 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My wall oven wont self clean because the automatic door lock wont lock what part do i change
Hi- The automatic door lock is a safety feature designed to prevent opening of oven door during 'self-clean', or as techs call it: 'self-destruct'. A previous full-power cycle has affected or destroyed a circuit or switch. The most common failures are the door switch, affecting the operation of door motor, or the control itself. - - -Start by replacing the door switch- available locally at an app. parts store. The electronic controls can also get 'cooked', causing a variety of faults, but these controls are expensive.------ On site diagnostics is needed many times. Remember---'self-clean' destroys circuits and controls eventually--every time. Don't let the salesman fool ya... Let me know if this info helps- have more if needed.  Thanks- Ed
Mar 16, 2010 | GE Ovens
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven wont come on
the oven door lock assembly has locked its self in to clean you can find the door lock assembly at the top of the oven where the door shuts sometimes if you push on the locking hook this will solve the problem
Dec 17, 2007 | Whirlpool RBS245PD Electric Single Oven
Ovens Logo
80 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
