Question about Frigidaire 24 in. GLD2162RDC Stainless Steel Built-in Dishwasher
I have a frigidaire dishwasher - model number PLDB998AC1. There are two spray arms in this dishwasher - lower and upper. The lower works fine but the upper spray arms are not spinning. There is what I think adequate water pressure coming in from the top but no movement on the upper spray arm. Here is what I know: 1) The water pressure and spray arms alternate between top and bottom. 2) The upper spray arm moves freely when I push it gently. 3) I have removed the pump and cleaned out any guck that has accumulated. 4) I have checked all hoses and there are no blockages. 5) I have run three empty loads with just about 1/4 cup vinegar to dissolve and scaling. But to all this, even with great water pressure coming into the upper arm funnel, there is no movement on the upper arms. I am stumped! Any help would be greatly appreciated. Thanks.
Noggin
  • 944 Answers
SOURCE: Upper rack dishes not coming clean.
You could try running it with the upper arm removed, just so you could be sure that the pressure is not getting to that point - unless you are absolutely sure the upper arm holes/channels are all clear then descale it overnight with some vinegar - just might clear something. if there is obviously only a little flow of water then perhaps you could try getting vinegar into the supply pipe using a basting bulb/syringe or similar - again leave overnight and you may get lucky. The next thing would be to take the machine apart so you could follow this hose through to the pump - undo it from the pump and blow through it or see if you can get a piece of wire in it from the pump end. try vinegar again. check the pump outlet for blockage. Hope this helps :)
Posted on Mar 14, 2007
bigg t
  • 640 Answers
SOURCE: tecnik integrated dishwasher 795/2
make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Posted on Aug 27, 2007
SOURCE: I have a Frigidaire Ultra
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Posted on Dec 14, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
SOURCE: Top wash arm does NOT spin, but is not blocked or
Remove the dishwasher from the cabinet and look at the hose going up to the top. Make sure it isn't clogged and that there is nothing in the port where it comes out of the pump. The top arm is powered by water pressure from the pump.
Posted on Jun 14, 2010
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
Dishwasher fills with water but doesnt spray water around
suspect the pump has failed .or the control board for it
Mar 03, 2018 | Frigidaire Dishwashers
Frigidaire dishwasher model pldb998ac1
If you use salt, maybe that needs refilling. Can't think what else would be low
Nov 08, 2017 | Dishwashers
Wont clean dishes
The little holes in the spary arms can block with general gunge etc. We use toothpicks, skewers to clear them. That sometimes helps.
Nov 16, 2011 | Dishwashers
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
Upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Sep 22, 2009 | Dishwashers
Upper spray arm fell off, can not repair nor find part
I had the same problem, but was able to find the replacement part at http://www.partselect.com/shipping.aspx. My old arm also has the number 1544681 on it. If needed use model number PLD2855RFC1 to locate the same part. Good luck!
Mar 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Upper arm does not spin
No I don't believe its the pump. I believe the lower spray arm is possibly split open on the side causing a loss of presure and flow to the upper arm and overloading the door seal. As well the loss of flow to the upper arm will resulted in it turning too slow.
Aug 12, 2006 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire 24 in. GLD2162RDC Stainless Steel Built-in Dishwasher Logo
190 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
