Question about PC Chips (M925G) Motherboard
I installed a new power supply on my pc cause it would not turn on at all, after installing the new power supply it turned on but then poered donw after a few seconds, what would cause this issue?
  • 53 Answers
A defective device (motherboard, hard disk, floppy, cd, dvd, fan) connected to the power supply can cause this problem. Try just connecting the motherboard and see if the unit will still power down after a few seconds. If it does then the motherboard is probably defective. If it did not power down, try connecting additional device one by one until you find the device that is causing the problem.
Posted on Jan 03, 2011
  • PC Chips Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
New power supply don't work
New Power Supply installed, computer won't boot up ...
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
May 22, 2013 - 6 posts - ‎2 authors
I have recently received my new power supply, i was very excited for it and just finished installing it. ... those were already 100$ on both the powre supplies, i don't want to .... Do you have another computer around that works?
New power supply now computer won't turn on [Solved ...
Jan 22, 2014 - 3 posts - ‎2 authors
Bought a new 500W power supply to replace the one of the same wattage. I wanted to ... This should turn the PSU on and the fans should work.
pc not booting after installing new power supply (pictures ...
Jan 01, 2016 | Computers & Internet
Sanyo DP50710 50'' plasma TV turns on power light then turns off/ on on its own. No picture. After checking all fuses and capacitors, we installed rand new power supply board. Still the sa
The set will need to be professionally diagnosed. There could be a # of things causing your problem. Playing the guessing game can get quite expensive.
Sep 23, 2012 | Sanyo Televison & Video
Installed a new graphic cards for Gateway DX4710-UB801A, it works for a day, but the next day, it wouldn't turn on, the power supply is not running.
Pull the new graphics card out to see if the power supply will start up, if no change, you will need a new power supply module.
May 11, 2012 | Gateway DX4710-UB801A (L-1015700R) PC...
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
Pc won't turn on. doesnt do anything after the power button is push. no lights,no sounds, no fans, nothing.
Most commonly that is caused by a burnt out power supply. You will need a little knowledge of assembling computers to know how to replace one, but an electronic store like Best Buy should be able to help with the purchase and installation of a new power supply.
Good luck.
Oct 18, 2010 | Computers & Internet
Acer aspir 5600, i pluged in and doesn't come on? power is on, just it is not take any power i guss
if the poer light turns on but nothing happens on the system possible the power supply on the motherboard which distributes the power to all the components of your laptop. and this means that you will need to have you system motherboard replaced, if I may have you tried removing the battery ans turning the system on using the adaptor only ? try it it the system turns on possibly the batter is causing the motherboard some issue on distributing the power to the system and may need to be replaced, try the batt first before going to the option of replacing the motherboard ^_^
Jun 06, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Comp. does'nt turn on. power is good
Your question fails to provide sufficient information.
.."doesn;t turn on power good...."
do any lights on the pc illuminate
was it working before, and did it close down correctly
has it possibly been hit by lightning
have you recently opened the case to install new hardware?
Possible causes of a failed power up.
dead power supply
a video card not seated in its slot correctly
dud motherboard
motherboard installed incorrectly
no Bios battery on motherboard
faulty wall switch
faulty power pack switch
no ram installed
and on and on
thanks for using FIXYA
Oct 10, 2009 | Intel Motherboard
Installed PCI-e vid card
U need to insure that the new Vid card is compatible to Ur pc. Does the pc power up without the new Vid card? If so it sounds like the card may be defective and shorts out the pc power supply.
Apr 01, 2008 | Sony VAIO VGC-RB42G PC Desktop
Will not power in
IT IS THE POWER SUPPLY HAS TO BE CHANGED ONLY THING IT COS AS MUCH TO FIX AS TO BUY A NEW UNIT AS I WAS TOLD UNLESS U KNOW WHER I CAN FID A POER SUPPLY FOR THAT MODEL
Nov 16, 2007 | Yamaha HTR-5560 Receiver
PC Chips (M925G) Motherboard Logo
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
