Question about Bosch 1297DK 14 Sheet Palm Sander Kit
Sandpaper keeps coming off while sanding. Why and how can I remedy situation. I was thinking about replacing rubber cover on clamp.
    New Friend:
I switched it to a new pad and the sandpaper is still flying off :( I just don't get it the paper is not even half used up. my sander is the hook and loop velcro one ugh its driving me nuts I have to keep buying more sandpaper when the sandpaper is not even worn out! BTW Mines a dewalt hook and loop random orbit sander
Posted on Nov 02, 2016
2 Suggested Answers
gs-speedbump
  • 9 Answers
SOURCE: sandpaper will not stick to rubber bed bosch
This is generaly due to previous adhesive buildup on the backing pad OR, the face of the backing pad is breaking down and cracking.There are two ways to handle this. You can try scrubing the crud off the pad (I wouldn't) or, you can get a new backing pad for your sander. At this point, you might want to go with a velcro type pad or hook and loop as they call it (cleaner and no goop). Check your local home depot for pads. If you cannot find one, I would suggest you call Klingspor abrasives Co. They have area reps all over the United States. I know, as I used to be one of them.They carry,.. and will send you pads via UPS. Just make sure you don't try to put a 6in pad on a 5in sander or vice-versa as the pads are weight-mated to the sanders. If you do, you will burn up the motor in your sander rather quickly.
Posted on Jan 27, 2010
How do you get the sandpaper on?
With a palm sander they are either self adhesive or you glue them on. Some have a clamp if the sandpaper is rectangular. It depends on what your sander is.
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3ASanding%20Disc%20Adhesive
Amazon com Sanding Disc Adhesive
Apr 28, 2016 | Tools & Hardware - Others
Re: B&D BDEQS300 sander: the front spring-loaded clamp no longer holds the sandpaper tightly. The paper continually slips off during use.
I am currently using a B&D palm sander to prep my walls by removing old panel adhesive so I can visualize your problem. The only solution I can think of (but have not tried) is to bend the wire clamps so they apply more pressure. Apparently B&D designers did not test these sufficiently with a variety of sanding sheet thicknesses before going into production.
Nov 17, 2017 | Tools & Hardware - Others
How often should you replace the sand on a SP714TX? my pool water is cloudy
Sand is cheap so replace it if you think that is the problem. i would be looking into water chemistry also. Take your samples of water to a reputable pool shop and let them test it. They will usually do it for free since most likely you will need chemicals to remedy the situation.
Dec 22, 2014 | Hayward SAND FILTER, PRO SERIES
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
DW411 Can I put a velcro pad on this sander so I don't have to fumble around trying to get sand paper on it
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 20, 2010 | Dewalt DW411 quarter - sheet palm grip...
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
I am recently widowed and don't know how to get the sand paper out of and onto the sander
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Oct 08, 2010 | Black & Decker 7448 1/3 Sheet Orbital...
Sandpaper keeps come off
probably the typer disk you are using. cheep disks will not stay on long.
Sep 29, 2009 | Bosch Power Tools Sanders Orbital Sanders
Pad on 9045B sander
Remove the bottom faom pad, which should just be held on with phillips screws. Under this you will see the eccentric weight that has a screw in the middle. Not sure if it is left hand thread or not so be carefull. It is normally thread locked aswell so be firm but fair when unscrewing it. Once it's out you should be able to lever the weight of by applying equal pressure to each side of it. It will be centered on a woodruff key so be cartefull not to lose it. Also, in between this part of the base and the main body of the machine there is a rubber skirt that is clamped to both parts. Unscrew the band clamping the skirt to the base and I think you should be able to pry it apart then.
Sep 07, 2008 | Makita Tools & Hardware - Others
How to attach sand paper to the Kirby Turbo Sander attachment?
There is a plastic guard around the edges that comes off. Then, there are clamps that hold each end of the sandpaper. If you can't see the clips, then the guard is still on and needs to be removed. Hope this helps...
Marci
Jun 23, 2008 | Kirby G5 Bagged Upright Vacuum
Bosch 1297DK 14 Sheet Palm Sander Kit Logo
1,035 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
