Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung WA71N2, plugged to 220V should be 110V only
i would like to know how to repair my samsung washing machine, it was accidentaly plugged to 220V instead of 110V, i do not know any electrical works so kindly help me with the procedures, i tried calling service center but nobody here in riyadh is answering thier service support.
regards
emir
Riyahd Saudi Arabia
edumaraos@dalkia.com.sa
  • Anonymous Mar 19, 2014
    do you have replacement for program selctor for Haier HE600TX model
  • Anonymous Mar 28, 2014
    wixl105 need mechanic
    door not lock/click
Chang the board! servise center will charge probably 400sr
Posted on Feb 03, 2010
Samsung printer 110v plug to 220v
You would have damaged the power supply section but in many cases the front end contains a surge protector with a variator which will short and blow the fuse. So check fuse replace and check for short in the input circuit of the power supply, if the Switch mode is damaged then you need to replace the unit with a 220 volt type or if only the 110 type is available then use a step down transformer to down the mains to 110V with about 0.5Amps
Oct 03, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Jun 17, 2011 | Samsung Washing Machines
Samsung SCX 4300 Printer Problem
Please change the SMPS. If only fuse is blown then u may add fuse only.
Mar 28, 2010 | Samsung SCX-4300 Monochrome Laser...
Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung washing machine WA71N2
can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Mar 07, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
395 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
