Question about Zenith SY2765S TV
Where do i find INPUT SELECTon zenith tv sy2779dt,trying to hook up Wii and default Wii screen does not come up. manual says to change IS. don't have orig remote, only dish 500.is there a way to change IS direct on front of tv? tknk u joe
    Scholar:
  • 85 Answers
Most tv's have a physical button on the front and it will either be labeled input or source-source select. If thats not the case on your tv, look for a menu button and try to navigate through the tv menus until you find tv input or source select. If that still does not work, you can use your dish 500 remote and if you already use that to turn the tv on and adjust volume, you can probably use it to change the input. To do this, select the tv mode on your dish 500 remote, and then press the source or input button until you get to where you need to be. Once thats done, make sure you return your remote to sat mode or you will not be able to control the dish reciever. Hope this was helpfull to you.
Thanks
Posted on Jan 03, 2011
Need remote for Zenith TV SY2779DT (manufactured in 10/96). A computer search leads me around in circles.
002,004,028,037,019,086,061 are the codes to check with Zenith brand TVs. If you wish to get more codes, check this link. It has setup code list to some popular models remote controls, from which you can find out the exact match universal remote control to your TV. If you want to buy its original one, contact the authorized service center for Zenith.
Feb 28, 2013 | Televison & Video
1997 Zenith tv, 27" i cannot find a remote or proper access code that will work on it.
Try out the Harmony remote - tad more expensive but very flexible and comprehensive.
Sep 06, 2017 | Zenith Televison & Video
Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
May 22, 2011 | Zenith C27A24T 27" TV
How do I program the tv to watch Wii?
You can use your remote to change the video source to the one you have your Wii plugged into on your tv.
  1. Press the Menu button on your remote
  2. Press Enter or the Right Arrow button to access the Setup menu
  3. Use the up/down arrow to select Main Input
  4. Press Enter or the Right Arrow to enter the Main Input menu and then use the Up/Down arrow to select the correct input.
  5. Press Exit to exit the menus and go back to full screen.
Note: The Input you want should be labeled where you plugged in the Wii.
The directions (with pictures) to do this are in the following link to page 25 of the manual for your tv:
http://www.fixya.com/support/p169140-zenith_e44w46lcd_44_in_rear_projection/manual-6442/page-25
Mar 03, 2011 | Zenith E44W46LCD 44" Rear Projection...
How the frick do u get to wii system working??
hook up the 3 cables coming from the unit to the back of the tv as followed red to red yellow to yellow white to white make sur that this says input 1 or 2 or aux use your tv controller and change input to desired input power on system and screen will load
Feb 13, 2011 | Nintendo Wii Console
How to connect a wii to my tv
Please take your AV Cord and hook it up to your wii and your tv. There are 3 colors. Red/White/Yellow
Once hooked up, take your remote and switch the Video Input on your tv. (look for the input button)
Make sure the Wii is powered on and you should see it pop up on the screen.
Dec 31, 2009 | Nintendo Wii Console
Cannot get wii hooked up to our new tv HD
try changing cables use diffrent input output don't
forget to set dvr on right setting , AV, L1 ect
have you got manual , if you are realy desperate to fix this you can call 0403960527 jeff
Feb 16, 2009 | Sanyo DS31590 31" TV
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Hooking WII to TV
check your using the correct AV channel for the connection. Try another input connector eg Scart
Jan 20, 2009 | Nintendo Wii Console
Cannot play videogames or DVD's
it might work like older tvs where u use a menu button to go through settings then u change settings i have an older tv and it is frustrating
Aug 20, 2008 | Samsung TXM2756 27" TV
Televison & Video Logo
346 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
