Question about Fisher and Paykel DEGX1 Electric Dryer
Electric dryer not heating. Already checked the breakers and the reset button.
  • 1,772 Answers
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Posted on Jan 03, 2011
Dryer is not heating. It is on but not heat. I have checked the breakers already and no luck.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Frigidaire Dryers
I have a speed queen electric dryer model number aem45300. problem the dryer runs but does not heat. We cleaned out all the area that contained lint. Is there a reset button for the heating element in...
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Mar 04, 2011 | Speed Queen AES17AWF Electric Dryer
Brand new dryer won't heat. Tumbles fine - but no heat. Maytag 2000 series. I already checked the breaker - no problem
heatman101
Jan 27, 2011 | Dryers
I don't have heat to my dryer.
Make sure that Front of the dryer is not blocked, Air flow is needed to dry.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty heating element.You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated
Jun 29, 2010 | Kenmore Elite HE4 Electric Dryer
I have a samsung dryer dv328aer that stopped heating up.
Check the home’s circuit breaker and fuses. Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Select a heat setting other than Air Fluff.
Clean the lint filter and exhaust duct.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Rating the solution is highly appreciated.
Jun 21, 2010 | Samsung DV328AE Electric Dryer
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Where is circuit breaker in a LG DLE9577WM dryer
it could be the thermostat it could be a burned heat element if electric verify gas or electric
Mar 05, 2009 | LG DLG5932W Gas Dryer
Whirlpool Electric Dryer stop working
could be a bad motor , or the starter on the motor.?? if you can hear the motor running then go for a new belt..
Jun 13, 2008 | Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
47 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
