Question about Yamaha RX-Z9 Receiver
Cannot get rxz9 out of zone 2 - Yamaha RX-Z9 Receiver
Sprinkler will not change zones
You mean timer will not change zones? Is it from zone 1 to zone 2? Does the timer say it is watering zone 2 and no water, does it default and shut down on zone 2? Does zone 2 have run time? Can you be a little more specific?
Feb 19, 2014 | Fimco 1-1/2 in. 10 psi 6 Outlet Indexing...
My RXZ9 has been in storage for about a year. Upon reconnecting the system, the audio is extremely low and distorted. This is typical of all inputs, including tuner, and all speaker and preamp outputs....
For this kind of issue, try checking if the RCA cables that was used is still working or not loose. If this amp was not used for a long time, try cleaning the RCA jack connectors on your amplifier, there is a possibility that if the cables were fine, it might be the RCA jack connectors have rust or corroded. Hope this helps.
Jul 10, 2011 | Yamaha RX-Z9 Receiver
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
Jul 07, 2011 | Onkyo TX-SR601 Receiver
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
My Denon AVR2308 is frustrating me. I am running two zones (5.1 in main and zone 2 out of rear surround). I have made the audio setting to allow Zone 2 on/off, but i am stuck on how to turn sound off in...
Greetings,
Unfortunately the AVR2308 does not have the zone 2 video output connector needed to pass video to a second zone. The AVR2808 was the first receiver in that year lineup to offer a video output to a second zone. There are many different types of video outputs on that receiver, but they are all associated with the Main zone. This is why you loose the video when you shut down the Main zone. With respect to your Zone 2; the small remote that came with the receiver should have all the power and volume features you need to operate Zone 2 while keeping the Main zone turned off. The only audio that can be passed to Zone 2 though has to be in an analogue format (using the red and white RCA connections). This receiver does not pass digital audio onto Zone 2. Best of luck!
Aug 21, 2009 | Denon AVR-2308CI
Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Jun 10, 2009 | Yamaha RX-V661 Receiver
Zone 2 must be on to hear zone 2
there are 2 ports for sub woofer, try using the other sub port.. I dont have to use zone 2, and not sure it even has a zone 2 sub port.... I use zone 2 for a cd player and speakers on the deck.. no sub woofer
Jan 02, 2009 | Onkyo TX-SR605 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Yamaha RX-Z9 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
