Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
My dishwasher does not clean right it leaves small bits of food and residue had a technician look at it at the toone of 75 dollars and told me there was nothing wrong with it.
  • LG Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
0-0
Posted on Feb 27, 2011
The dishwasher does not always drain completely after a cycle. But the biggest problem is that dishes are clean but aren't rinsed completely leaving a bumpy residue of small food particles. Most noticeable...
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Kenmore Dishwashers
My glasses have a white film residue plus small bits of food residue on them. I tried a dishwasher cleaner with minimum results. Could a try a product like CLR? I wouldn't want to completely etch my...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 16, 2010 | GE 24 in. PDW8980LSS Stainless Steel...
Dishwasher is about 8 years old an dishes are just not as clean. Looks like they have a bit of residue on the dishes. Dishes clean in terms of food, but just not squeaky clean look anymore. Way to clean...
heatman101
Aug 21, 2010 | Asko D1876 Dishwasher
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Bosch dishwasher leaving food stains
You may be experiencing this problem due to the soap you use or too much soap. Run a cycle without soap but put a cup of white vinegar in the machine. Then just use Cascade dishwashing packets. If your filters are clean and the pump is working that should take care of your problem. Do NOT use the inexpensive soaps on the market and especially don't use more than what is recommended. This leaves a film on your dishes and will cause it not to clean or rinse well. (I don't have any connection to Cascade - I just know it works very well. Costco brand packets also work well.)
May 19, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Maytag quietseries 300 leaves residue after washing...(leftover food bits, etc.)....is there a filter to clean out or something??
Dishwasher
How to Buy
heatman101
Mar 15, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
It is not cleaning dishes, it leaves food residue on dishes and deposits small bits to other dishes especially on glasses.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Jul 15, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
197 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
