Hi there, the socket where the wire goes for my external hardrive has been broken. The pins are bent and cannot b moved. Can you please lend me advice on what to do? i have so much valueble photos etc that i dont want to lose! cheers
    Problem Solver:
  • 17 Answers
Go and buy new one your device is already useless because the pins are bent if the pins are bent it is useless
Posted on Jan 03, 2011
2011 KTM 990 Adventure low beam blows and speedometer goes out
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight and taillight out
KTM Super Twins Forum
KTM 2003 950 Adventure Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 990 ADVENTURE EU Owner Manual
May 31, 2017 | 2011 KTM 990 Adventure
Bike headlamp wireing problem headlamps getting very hot and keep blowing and when both connected up the high beam dash light goes out like they are drawing too much power.
Hi Anonymous, if your headlight is not working, keeps burning out or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Bandit 1200 Electrical problem
Bandit electrical problem
http://www.carlsalter.com/download.asp?p=1503
Jan 06, 2016 | Suzuki GSF 1200 Bandit S Motorcycles
Is the pig tail assembly on rear of the isteam control replaceable. Mine has a broken pin from the male connector inside and we cannot get it out. Thanks
If the pin is hollow (as all I've seen) try a wire with a hook on the end, a very small screw or possibly a small screwdriver to be able to pull the pin out of the socket.
Nov 28, 2014 | Mr Steam Butler Package 2, Square...
2004 Honda VT 750 Shadow Aero headlight not working
Hi, Brett if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
3. Worn, chafed, or broken wires in the light circuit.
10. Weak charging alternator/generator/lighting coil
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Headlight problem
Headlight stopped working
Honda 1998 VT750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Aug 09, 2012 | 2004 Honda VT 750 Shadow Aero
My washing machine drains,but when on a cycle the drum doesn't move at all and it doesn't go into spin mode?
Check the actuator for the lid switch to make sure it isn't bent or broken. To find the lid switch, look for a pin on the lid that goes through a hole in the top of the machine when the lid is closed. The lid switch actuator is under this hole. If you can't see the actuator lever through the hole, it's probably bent off to the side or broken off. It's also possible to see it, but it's bent down to far to be actuated by the pin. If the lid is bent or the pin is broken off, that would have the same effect.
Apr 04, 2012 | Washing Machines
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
How to install CPU- Intel Pentium Dual Core E5200 into a asus barebone system P4-P5N9300pc please?
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Sep 23, 2009 | ASUS Computers & Internet
No back light on screen
Hi there.
If the external monitor is working fine I'd disassemble the the screen again and reassemble it taking particular attention of the cable connectors and sockets.
Make sure all plugs are in the sockets nice and tight and also look at the motherboard socket for any bent pins.
You will need good lighting for the job and possibly even a magnifying glass.
Please post back if you need anymore help.
Good luck
Jun 11, 2009 | Dell Latitude C610 Notebook
External hardrive wont transfer data
looks like the usb connection pins are not touching the other connection pins. just check the pins touch each other surface then the data will transfer. check all four pins. if it is a standard A connector then far two pins are power supply and middle two pins are data pins.
v- data- data+ v+
the above are the pins in a standard usb connector
Apr 19, 2009 | Computers & Internet
Usb connection failure
ok" take a small needle , streighten the pin very carefully.
Jan 21, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
David Payne
David Payne
