Question about Dell 5210n Laser Printer
5210n fuser error code - Dell 5210n Laser Printer
  • 583 Answers
The fuser unit needs to be replaced. This is most likely due to the fuser heating element no longer heating the fuser adequately.
Posted on Jan 03, 2011
  • chip822 Jan 03, 2011
    replaced it because I got that eroor message. still has the same message
Close door or replace cartridge message won't go away
Replace the imaging drum and reset the life counter on Dell ...
www.dell.com/support/article/us/en/19/SLN142828/EN
DellOct 31, 2014 - Obtain replacement part; Fit replacement part; Reset life counter ...counter on Dell 1700, 1710, 1720, 2230, 2330, 2350, 3330 and 3335 laser printers. ...toner low and error lights, 23xx and 33xx will display the message Replace PC Kit. ...Fit the assembled toner and drum to the printer, close the front door.Missing: 5210n ‎persistent
34 Short Paper Error on Dell 5210n, 5310n Printers ' Dell US
www.dell.com/support/article/us/en/19/SLN133464
DellMay 10, 2013 - If the pegs do not change position, the gray paper size guide may have become separated ... On the left side of the inside of the printer, under where thecartridge goes, there are two white ... Close the upper and lower doors.Missing: laser ‎message ‎persistent
Dell Printer -- Feeder Problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/29793
Aug 28, 2008 - I am having trouble with my Dell 1700 laser printer. ..... the printer jams in the middle, I get the message, but opening and closing the front door will allow the..... I replaced the cartridge just in case,(the tape had been removed!) ...
Jan 08, 2016 | Dell 5210n Laser Printer
How to fix a Dell 5210N 900 RIP Error?
Replace printhead. If Dell can't be found or is cost prohibitive, use a refurb/reconditioned Lexmark T640 series printhead.
Aug 26, 2014 | Dell 5210n Laser Printer
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
My Dell 5210n printer has a very loud squeak in the back. How do open the printer to lubricate the bearings?
Usually you don't lubricate. It is probably the fuser assembly wearing. How is the print quality? Have you ran a test page, ran a supply status page? Checked the error log?
Jan 17, 2013 | Dell 5210n Laser Printer
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
What does the 922.02 service fuser error mean? Will not print,
It means the fuser (roller than heats the toner to the page) has a problem, most like needs to be removed and cleaned or replace.
Jan 17, 2011 | Dell 5210n Laser Printer
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
Dell 5210n Laser Printer Logo
226 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
