Question about Jenn-Air PRG4810 (NP) Gas Kitchen Range
I bought the Jenn Air Gas Range (model no. JGS8860BDP) and when i tried to turn on the oven for the first time, there was fire coming out of the back. Is this normal?
pranaclimbin
  • 50 Answers
SOURCE: I am having a hard
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=svd48600
click this link, then choose your model, then on the left side under select diagram scroll down to # 7 oven, and presto.
Posted on Dec 04, 2008
  • 58 Answers
SOURCE: gas range igniters won't shut off
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
Posted on May 28, 2009
richardsimpl
  • 230 Answers
SOURCE: F2 signal on Jenn-Air model su146 range
Hi there
i have found the code for and hope this helps you.let me know how it goes.
F2 Oven too hot Replace relay board (if present) or oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Posted on Mar 22, 2010
Joshi_Z
  • 567 Answers
SOURCE: JGS8860BDP Jenn Air 300" Range
I understand that a few buttons (Top 2 rows) are not working on the kitchen range.
An issue like this is most often caused by a problem in the control panel's keypad.
Resolving this requires the control panel to be replaced.
Posted on Oct 08, 2010
  • 11800 Answers
SOURCE: Jenn-air jgs8860bdp oven has strong gas smell when
Either the flame is incomplete at the burner of the oven or there is a leak. Simple tests:
1 - remove everything from the oven - even the panels that slide out, light the oven and look at the flames while rotating the button: if the flames flicker or die out then the air intake at the jet is badly adjusted.
2 - if the flame is steady then it's a leak - for that you must call a certified repairman, the oven must be dismantled for the entire gas piping to be tested.
Posted on Oct 26, 2010
Oven heats up to set temperature of 500 degrees, and shuts off completely on its own. replaced electronic control, and it still does the same thing. Any suggestions??
Does it have a thermostat to regulate the temps? If it is working correctly it will turn the element on and off to maintain the set temp.
There is also some thermo couple in there to regulate the flow of gas. If that goes haywire gas does not flow properly and ........
Nov 24, 2015 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn air gas kitchen range, front keypad is not working
I have the same problem. Please let me know if you have found a solution
Jan 27, 2011 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Gas range igniters won't shut off
May 28, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn air gas/elctric slide in range self cleaning does not work
iF THEY ALREADY REPLACED THE EXHAUST FAN , MAY WANT TO REPLACE THE HI LIMIT THERMOSTAT AT REAR OF OVEN... THE THERMOSTAT MAY RESET AFTER 20 MININUTES OF COOL DOWN..
Apr 02, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
My electrician is here to do the electrical for my new Jenn-Air Gas stove Model # JGS8860BDP.  The store said we need both 110 and 220 outlets inside the stove space.  My electricial doesn't think...
Trust the Electrician. 99.9% of the time, the only requirement for working at a retail store is to know absolutely NOTHING of the product they sell. Where an electrician is liable for any damage to property or person injured due to his/her work... not to mention to 2 years of required training to get your journeyman lisence.
Jan 13, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Have a slide in Gas Jenn Air model JGS8860BDP, but no manual. Ho
Google your range (i.e. Jenn Air JGS8860BDP). You will be brought to Adobe Reader which will have a copy of the User Guide for your range. Doenload it to your computer, or print it directly.
Nov 11, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn Air Older Oven wall unit only
Shannbooks The first thing I would recommend to do is to reset the power. Turn off the breaker for the range for couple minutes and then turn it on. In the most cases it works. Set the time of the day and try to use the oven. If it would not solve the problem let me know. Good luck. Gendos. post back...
Jul 08, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air PRG4810 (NP) Gas Kitchen Range Logo
29 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
