Question about GE GTS22WCP Top Freezer Refrigerator
Besides the on and off switch, how do you turn on this icemaker? We have turned it on, and nothing happens.
  • 50 Answers
There is a wire lever that flips up and down. This is to turn off the icemaker when the tray is full.
Make sure that wire lever is in the down position.
Hope this helps!
Posted on Jan 03, 2011
  • markn20549 Jan 04, 2011
    As far as I know, we have no wire lever that goes up and down. It only goes horizontally, against the ice maker.
  • Mark Carey Jan 04, 2011
    On the right side of the icemaker there is a wire lever probably encased in white rubber. If you can't see it, it's probably down or in the on position. The lever is there so that when the ice tub gets full the icemaker will shut off.
    Have you checked the incoming water line? There is a valve that turns the water off and on somewhere on that water line, usually in the basement or under the sink. If that lever I spoke of earlier is on, or down and the icemaker is getting water it should work.
    Hope this helps
Turned it on, checked volume and nothing happens. Is there another switch that I need to turn on besides the on buttong
Turned what on and pressed what button and pressed what button.this is the motorcycle section btw
Mar 08, 2015 | Motorcycles
2001 Lincoln ls no crank no start no power to gages aint got ne lights that work when you turn key on nothing. Happens besides air bag light stays on
Not familiar with security systems, but could be a blown fusible link, or bad Ignition switch. Test for current to switch and if none (usually bid red wire) check for blown fusible links near starter big wire or battery +.
Jan 15, 2015 | 2001 Lincoln LS
Ice maker not making ice
Try raising and lowering the bar several times then make sure that the bar is in the lower position. If that doesn't work, you may have to replace the icemaker unit. You can find them at a supply house.
Aug 11, 2014 | GE Refrigerators
GE Icemaker
Switch sounds like its sticking. Micro switch needs to be replaced
Jul 25, 2013 | GE GSL22JFXLB (22 cu ft) Side by Side...
My HP G62-355DX goes to a white screen randomly and there's nothing I can do to fix it besides turning it off for a while. I've tried unplugging and plugging the video cable back in and I'
TRY HOOKING THE LAPTOP TO AN EXTERNAL MONITOR IF THE MMONITOR IS OK. THEN ITS THE CABLE CONNECTING THE KEYBOARD TO THE SCREEN. HOPE THIS HELPS. THS HAPPENED TO ME GOOD LUCK
Jan 20, 2012 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
I have a whirlpool refrigerator model ed5vhgxml10 and the icemaker is not working I switched the wires on the water valve with the water in the door and it put water into the icemaker then I jumped T and H...
If you jumpered T and H for at least 10 seconds and nothing happened. There is no power to the ice maker or the ice maker has failed internally.
Sep 11, 2009 | Refrigerators
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
New GE profile bottom freezer fridge intermittent buzzing
If the buzzing is a short (say 5 seconds) every once in a while, it sounds like the water is valve being energized. That would mean the icemaker is turned on and is cycling. Besides the noise, when it cycles it turns on the mold heater, which you do not need if not making ice, and thus is actually adding heat to your freezer, increasing operating cost. Just turn the icemaker off by flipping the toggle switch on the icemaker itself. It is a white switch near the bottom corner of the icemaker. Should be easy to spot.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GTS22WCP Top Freezer Refrigerator Logo
125 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
